With four operating modes and a long battery life, being productive on the go has never been easier thanks to the HP Spectre Pro X360.
With a touchscreen, as well as the ability to use it as a notebook, tablet, in stand or tent mode, you can make this Spectre laptop work for you.
Powered by an Intel Core i7 processor, the HP Spectre laptop comes with 8GB memory and speedy 256GB solid state drive so you don’t have to compromise on performance even when working on large files.
Connect instantly to the internet wherever you are with the 802.11ac wireless technology and transfer data quickly and efficiently using Bluetooth 4.2.
Looking for enhanced security to keep confidential data secure? With the HP Spectre, you’ll benefit from the Trusted Platform Module security chip and Intel Anti-Theft Technology (iAT).
Transporting your laptop from A to B is easy on account of it weighing just 1.48kg. Measuring 32.5cm x 21.8cm x 1.54cm, it’s ultra-thin to fit easily into your bag when you’re on the go.
