The sleek, precision-crafted HP Spectre Pro x360 offers the benefits of flexible 360 degree hinge movement and four operating modes. Stay productive with long battery life on an x360 business convertible with 6th Gen Intel Core i5/i7 processors and optional vPro .
- Windows 10 Pro 64
- Intel® Core™ i5-6200U processor
- 33.8 cm (13.3") diagonal Quad-HD touch screen (2560 x 1440)
- 8 GB RAM and 256 GB SATA SSD
Break from the conventional with 360 degree flexibility
Sturdy lightweight aluminum creates a seamless look on this incredibly thin (.61 in. / 15.4 mm.) convertible PC. Starting at just 3.2lbs / 1.45kg, easily switch between four different user modes on the 33.8 cm (13.3") diagonal touch FHD or QHD touchscreen.
Power for hours
Never slow down with long battery life that allows you to create, stay productive, and entertain without having to recharge.
Premium performance
Take charge of your workday with Windows 10 Pro and powerful 6th Gen Intel® Core™ processors with optional vPro™ technology.
Field ready
Never fear bumps and minor spills. The thin and light HP Spectre Pro x360 is designed to undergo MIL-STD 810G testing.
Featuring
Let nothing stand in your way
The best features of your favorite Windows OS and new features come together in Windows 10 Pro.
Take HD up a notch
Lifelike Full HD with an optional QHD ultra-resolution 33,8 cm (13.3") touch diagonal display.
Flexible productivity
Get through your busy day using a notebook and simply fold the 33.8 cm (13.3") diagonal screen over to go between tablet, stand or tent mode and stay connected on the go.
Help secure critical data
Encrypt your SED or SSD drive with Windows BitLocker and TPM 2.0.
Cloud-based IT management made simple
Manage data, security, and devices from a single cloud-based solution with HP Touchpoint Manager.
Road ready
Work in more places with multiple connectivity options to help you stay connected on-the-go.
One smart pen
Help improve productivity with the optional HP Executive Tablet Pen.
