One and Only HP's lowest-power all-in-one smart zero client, delivering PC-like performance using a single wire for power and network connectivity. Simplify your desktop with zero management and zero compromise.
Create a powerful, client virtualization environment with a streamlined all-in-one solution that combines thin client security and management for impressive PC-like performance.The innovative design features an 18.5" diagonal LED monitor for a small desktop footprint.
Power-over-Ethernet
Experience our lowest powered, all-in-one smart zero client with Type 1 Power-over-Ethernet – designed to operate within a 13-watt power envelope at 200 nits of brightness through Power-over-Ethernet.Benefit from a faster, one-wire set-up. Just plug in your Power-over-Ethernet wire and you're ready. No A/C attach required.
PC-like Performance
Built using a high performance Texas Instruments TMS320DM8148 ARM?R CortexTM processor with 1 GB DDR3 SDRAM and 2GB eMMC Flash memory capacity.Supports Microsoft , Citrix and VMware VDI implementations in a single "appliance" set-up.Featuring DSP Acceleration for RemoteFX and ARM Neon extensions for Citrix SoC for a more flexible user experience.
HP Smart Zero Client Technology
Improve network performance and the end-user experience with HP Velocity software.Simplify your IT atmosphere with complete configuration and reconfiguration control over your operating system.Automatic Intelligence, inherited by HP Smart Zero Client Services, establishes a secure desktop environment for all devices in minutes, and downloads everything it needs to deliver a robust user experience.If your client virtualization software changes your HP Smart Client will adapt to your environment. Simply repurpose your HP Smart Client for another protocol, saving time and money.
Eco-highlights
Help reduce your company's operating costs with HP's first, ultra-low power, Type 1 PoE – Power-over-Ethernet – all-in-one smart zero client solution.The HP t410 All-in-One Smart Zero Client also leads the industry in the development of environmental thin client technologies: ENERGY STAR qualified, EPEAT Gold registered, Low halogen materials.
Backed by HP
HP Thin Clients are backed by HP global service and support through our network of over 50,000 IT professionals in over 100 countries.The HP t410 All-in-One Smart Zero Client includes a standard, three-year limited hardware warranty in most regions.
HP Smart t410 - all-in-one - Cortex-A8 1 GHz - 1 GB - flash 2 GB - LED 18.5"
Zero client - all-in-one - PC over IP (PCoIP) technology
1 x ARM Cortex-A8 1 GHz
Cache Memory
256 KB L2 Cache
Cache Per Processor
256 KB
RAM
1 GB DDR3 SDRAM
Hard Drive
Flash 2 GB
Optical Storage
No optical drive
Monitor
18.5" - LED - 1366 x 768 (HD)
Audio Output
Stereo - integrated
GigE
OS Provided
Software Included
VMware View Client, Citrix ICA 12.0, HP Device Manager, Microsoft RDP 7.1
44.93 cm x 15.91 cm x 34.1 cm
3.65 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 3 years
Zero client
Recommended Use
Small business, corporate business
Product Form Factor
All-in-one
Processor / Chipset
CPU
ARM Cortex-A8
Clock Speed
1 GHz
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Not upgradable
Cache Memory
Installed Size
L2 Cache - 256 KB
Cache Per Processor
256 KB
RAM
Installed Size
1 GB
DDR3 SDRAM
Effective Memory Speed
400 MHz
Hard Drive
Flash
2 GB
Optical Storage
No optical drive
Monitor
Monitor Type
LED
Diagonal Size
18.5"
Native Resolution
1366 x 768 (HD)
Widescreen Display
Graphics Controller
Integrated
Audio Output
Integrated
Sound Output Mode
Stereo
Max Sampling Rate
96 kHz
Input Device
Mouse, keyboard
Integrated
Wake on LAN (WoL), DHCP support, PXE support
4 x USB 2.0 (2 front, 2 rear) , 1 x microphone , 1 x headphones , 1 x LAN (Gigabit Ethernet)
Theft/Intrusion Protection
VESA Mounting Interface
100 x 100 mm
VCCI, EN 61000-3-2, EN55022, ZH1 618, EN 61000-3-3, EN55024, FCC, FCC CFR47 Part 15, UL 60950-1, IEC 60950-1, EN 60950-1, CSA C22.2 No. 60950-1-07
Power adapter
Power Provided
24 Watt
Operating System / Software
OS Provided
Software
