Scan documents on the spot, wherever you are--in the office, in the field or on the go--with the HP compact, portable scanner. Organize contracts, forms, receipts and business cards on your PC instead of on your desk or in your briefcase.
Digitize documents nearly anywhere and on the go.
- Capture documents on the spot--in the office, at your customer's site and even on the road.
- Carry and use the scanner almost anywhere--it's lightweight, portable and compact.
- Protect and store the scanner in the included sturdy carrying case.
- Power the mobile scanner via your PC's Hi-Speed USB 2.0 port--no batteries or AC adapter needed.
Easily scan and organize your digital information.
- Scan with the touch of a button or scan directly from the application you're working in.
- Scan in different file formats--PDF, TIFF, JPEG, Microsoft Word--and save disk space with smaller file sizes.
- Archive files with Nuance PaperPort, and convert scans into editable files with Nuance OmniPage.[1]
- Scan and organize business cards and embossed cards, using NewSoft Presto! BizCard Reader software.[1]
Quickly scan a variety of two-sided documents.
Save energy with Instant-on scanning technology
Reduce clutter and waste--scan and share documents digitally
Reduce packaging waste, contains innovative, reusable tote made from recycled plastic bottles
ENERGY STARĀ® Qualified
HP Scanjet Professional 1000 Mobile Scanner
http://www.hp.com/ecosolutions
- Scan a variety of paper sizes, from business cards to long forms.
- Scan at up to 5 ppm or two-sided in a single pass at up to 8 ipm, using the manual feed slot.
- Capture all the detail and fine print at up to 600 dpi scanning resolution.
