Abandon paper-based workflows. Advance office efficiency with fast, intuitive scanning that turns hard copies into useful digital data. Rely on clear, legible results from a compact scanner designed to enhance collaboration.
Send scanned files where you need them – directly to cloud storage or SharePoint .File size matters – ensure files are saved with size in mind – automatically compress large files.Straighten out your paper shuffle – transform hard copies into easy-to-use files.Look sharp by producing clear, legible scans at up to 600-dpi resolution.
Simple scanning – ready, set, go
Save time and simplify complex scan jobs with HP Smart Document Scan Software.Fits in around the office – preserve workspace with a compact scanner designed to fit your floor plan.Create one-touch scanning efficiency by assigning your favourite settings to a single button.IT time and effort, saved – simplify deployments, installations, and event alerts.
Page-by-page confidence
Accurately capture the right content, using auto-scan mode, crop, and colour detection.Full speed ahead – breeze through sheet after sheet at speeds of up to 30 pages and 60 images per minute.Count on this workhorse to deliver again and again with a design that can handle up to 4,000 pages per day.Spend energy wisely – this scanner turns off automatically when it's not needed to help reduce energy costs.
HP ScanJet Enterprise Flow 5000 s3 Sheet-feed Scanner - document scanner - desktop - USB 2.0
Document scanner - desktop
Interface Type
USB 2.0
Scanning Sensor Type
Contact Image Sensor (CIS)
Light Source
LED
Additional Functions
Scan to cloud
Max Supported Document Size
216 x 3098 mm
English, German, French, Italian, Spanish / Europe
Input Type
Grayscale / Color Depth
8-bit (256 grey levels) / 48-bit colour
Grayscale / Color Depth (External)
24-bit (16.7 million colours)
Optical Resolution
600 dpi x 600 dpi
Max Document Scan Speed
30 ppm (mono) / 30 ppm (colour)
Max Document Size
216 mm x 3098 mm
Automatic Duplexing
Supported Document Type
Plain paper, business card, plastic card, labels, envelope
Document Feeder Type
Automatic
Document Storage Capacity
50 sheets
Duty Cycle
4000 scans per day
Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows XP SP3 or later, Windows 8
31 cm x 18.24 cm x 18.38 cm
4.82 kg
Environmental Standards
ENERGY STAR Qualified
Interface Type
USB 2.0
Scan to cloud
216 x 3098 mm
Scanner
Input Type
Grayscale Depth
Colour Depth
48-bit colour
Colour Depth (External)
Optical Resolution
600 dpi x 600 dpi
Scan Mode
Single-pass
Automatic Duplexing
Bulb / Light Source Type
LED
Max Document Scan Speed B/W
30 ppm
Max Document Scan Speed Colour
30 ppm
Duty Cycle
4000 scans per day
Scanner Speed Details
30 ppm - black & white - 300 dpi , 30 ppm - colour - 300 dpi , 60 ipm - black & white - 300 dpi , 60 ipm - colour - 300 dpi
Scanner Features
Automatic Separation, Automatic Image Orientation, automatic page size detection, Auto Crop, auto power off, Auto Straighten, Ultrasonic Multi Feed Detection, HP EveryPage
TWAIN, ISIS
Media Handling
Max Document Size
216 mm x 3098 mm
Supported Document Size Details
ADF - up to 216 x 3098 mm
Automatic
50 sheets
Interfaces Details
USB 2.0 - Type B
Cleaning cloth
1 x USB cable
CSA, CISPR 24, SASO, CISPR 22, EMC, IEC 60950-1, UL 60950-1 Second Edition, EN 61000-3-2:2006, EN 61000-3-3:2008, EN 60950-1:2006, EAC, EN55022:2010
ENERGY STAR Certified
External power adapter
Power Consumption Operational (Standby)
26.4 Watt
Software Included
Readiris Pro, Nuance PaperPort, HP Smart Document Scan Software, Cardiris Pro
System Requirements Details
Windows Vista/7/8 - 2 GHz - RAM 2 GB - HD 177 MB (USB 2.0) , Windows XP SP3 - 1.6 GHz - RAM 1 GB - HD 177 MB (USB 2.0)
