Mobility without compromise. Maximize productivity with the convenience of a tablet and the power of a notebook. Work confidently in or out of the office with commercial grade security and connectivity.
Optimized for productivity, the HP Pro x2 612 tablet packs in all the features you rely on including a large display with the built in connectivity, security, and high performance you need for everyday business.
High performance tablet
Replace your traditional notebook with a tablet that lets you perform at your best with the choice of 4th Gen Intel Core processors, fast SSDs, and longer battery life when paired with the optional power keyboard.
Security for business
Replace your traditional notebook with the HP Pro x2 612 G1. 2-in-1 solutions let you perform at your best with optional 4th generation Intel Core i3/i5 processors, fast solid state drives, and longer battery life when paired with the optional HP Pro x2 612 G1 Power Keyboard.
Tablet or 2 in 1, you choose
Purchase your complete business mobility solution today. Choose the optional power keyboard with the optional HP UltraSlim Docking Station, or the travel keyboard for a lighter option.
Featuring
Enjoy smooth and precise interaction with select models using the optional HP Pro x2 612 Wacom Pen with high performance pressure sensitivity and smart palm rejection technology.Functions as a full notebook by utilizing two USB 3.0 ports, DisplayPort, VGA and RJ45 on the HP Pro x2 612 G1 Power Keyboard. The Power Keyboard also supports enterprise docking with a side connector for the optional HP UltraSlim Docking Station.The HP Pro x2 612 Travel Keyboard helps you travel light and stay productive on the go.Easily collaborate with colleagues using the 12.5-inch diagonal FHD tablet with an optional Wacom Pen, Qualcomm Gobi 4G LTE, dual HD webcams, and HP Noise Reduction Software.Get to work virtually anywhere in the world with fast, reliable, and secure wireless connections using optional Qualcomm Gobi 4G LTE connectivity.
1080p Full HD movie recording, low light enhancement
Sound
Stereo speakers, two microphones
Codec
Realtek ALC3228
High Definition Audio, DTS SOUND+
Input
Keyboard, touchpad
Keyboard Backlight
Volume control, spill-resistant
Communications
Wireless
802.11a/b/g/n, Bluetooth 4.0
Bluetooth Class
Class 2
Wireless Controller
Intel Dual Band Wireless-N 7260AN - PCI Express Half Mini Card
Network Interface
Gigabit Ethernet
IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED
Lithium polymer
Installed Qty
2
AC Adapter
Input
Output
45 Watt, 19.5 V
Connections & Expansion
USB 3.0 , Headphone/microphone combo jack , 2 x USB 3.0 (on keyboard dock) , DisplayPort (on keyboard dock) , VGA (on keyboard dock) , Headphone/microphone combo jack (on keyboard dock) , Dock (on keyboard dock) , LAN (on keyboard dock)
Cyberlink PowerDVD, Skype, HP Support Assistant, HP ePrint, HP Hotkey Support, Netflix, Foxit PhantomPDF Express, Absolute Data Protection (90 days trial), HP Spare Key, Microsoft Internet Explorer 10, Windows Defender, HP Client Security, Device Access Manager with Just In Time Authentication, HP PageLift, HP File Sanitizer, Microsoft Internet Explorer 11, Drive Encryption, HP Manageability, Box.net
