Featuring extensive cable management and a sleek design, this AiO suits the front desk or an owner's office. The micro-edge, anti-glare 21.5-inch diagonal IPS display provides plenty of workspace.
Power through your day with Windows 10 Pro and the powerful security, collaboration and connectivity features from HP.
Automatic recovery from firmware attacks
Firmware attacks can completely devastate your PC. Stay protected with HP's self-healing BIOS - HP Sure Start Gen5 automatically recovers the BIOS from malware, rootkits, or corruption.
Work without interruption
Keep productivity high and downtime low with the fully integrated and automated features of the HP BIOSphere Gen5 firmware ecosystem. Your PCs have extra protection thanks to automatic updates and security checks.
HP Sure Sense
Malware is evolving rapidly and traditional antivirus can't always recognize new attacks. Protect your PC against never-before-seen attacks with HP Sure Sense, which uses deep learning AI to provide exceptional protection against advanced malware.
HP ProOne 600 G5 - all-in-one - Core i5 9500 3 GHz - 8 GB - HDD 500 GB - LED 21.5" - UK
21.5" - LED - 1920 x 1080 (Full HD) - 16:9 - touchscreen
Graphics Controller
Intel UHD Graphics 630
Audio Output
Stereo
GigE, 802.11a, 802.11b/g/n, Wi-Fi 5, Bluetooth 5.0
Keyboard
AC 120/230 V
OS Provided
Windows 10 Pro 64-bit Edition
Software Included
HP Support Assistant, HP ePrint, HP Hotkey Support, Windows Defender, HP Secure Erase, HP Drive Packs (free download), HP BIOS Config Utility, HP Setup Integrated OOBE, HP JumpStart, HP Noise Cancellation, HP System Software Manager, HP JetAdvantage, HP Sure Click, HP Manageability & Integration Kit Gen3 (free download), HP BIOSphere Gen5, HP Client Security Manager Gen5, HP Privacy Settings, HP Cloud Recovery, HP Sure Sense, HP Image Assistant Gen4
48.91 cm x 20.847 cm x 36.369 cm
5.79 kg
Limited warranty - parts and labour - 3 years - on-site
Personal computer
Product Form Factor
All-in-one - with height-adjustable stand
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
Intel Core i5 (9th Gen) 9500
Clock Speed
3 GHz
Max Turbo Speed
4.4 GHz
Number of Cores
6-core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
Processor Main Features
Intel Turbo Boost Technology 2, Intel Smart Cache
CPU Socket
LGA1151 Socket
Chipset Type
Intel Q370
Cache Memory
Installed Size
9 MB
Cache Per Processor
9 MB
RAM
Installed Size
8 GB / 64 GB (max)
DDR4 SDRAM - non-ECC
Effective Memory Speed
2666 MHz
Rated Memory Speed
2666 MHz
SO-DIMM 260-pin
Slots
2 (Total) / 1 (empty)
Unbuffered
Configuration Features
1 x 8 GB
Hard Drive
HDD
1 x 500 GB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Optical Storage
DVD-Writer
Monitor
Monitor Type
LED - IPS
Touchscreen
Yes (10-point multi-touch)
Diagonal Size
21.5"
Native Resolution
Widescreen Display
Image Aspect Ratio
16:9
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Colour Gamut
72% NTSC
Pixel Pitch
0.24795 mm
Response Time
14 ms
Image Brightness
250 cd/m²
Image Contrast Ratio
1000:1
Monitor Features
Full HD anti-glare, Projected Capacitive Touch (PCT) technology, 72% NTSC colour gamut
Graphics Controller
Graphics Processor
Video Interfaces
DisplayPort
HDCP Compatible
Audio Output
Sound Output Mode
Stereo
Max Sampling Rate
192 kHz
High Definition Audio
Speakers Included
2 x right / left channel
Input Device
Mouse, keyboard
Keyboard
USB
Localization & Layout
Mouse
Optical
USB
Wireless LAN Supported
Wireless NIC
Intel Wireless-AC 9560
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 5.0
Wake on LAN (WoL), ACPI support, auto-uplink (auto MDI/MDI-X)
1 x USB 2.0 - Type C (charging) , 4 x USB 3.1 Gen 1 (2 rear) (one of them is fast-charging) , 1 x DisplayPort , 1 x headphones/microphone , 1 x LAN (Gigabit Ethernet)
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
ACPI, RoHS, WEEE, low halogen
Power adapter
AC 120/230 V
Power Provided
120 Watt
Efficiency
88%
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Windows 10 Pro 64-bit Edition English
Software
Dimensions & Weight Details
48.91 cm - 20.85 cm - 36.37 cm - 5.79 kg - with stand
