Easy to deploy, sleek, and feature-rich, the HP ProOne 400 G3 50.8 cm (20") All-in-One PC with business-class collaboration, optional touch, manageability, and security features is a sound investment.
Be productive in any situation. Windows 10 Pro and powerful security, collaboration, and connectivity features from HP help you power through your day on the HP ProOne 400 AiO.
Super secure. Super protected
Guard your data, device and identity with HP Client Security Suite Gen3.
Work without interruption
Keep productivity high and downtime low with HP BIOSphereGen3 firmware-level automation. Your PCs have extra protection thanks to automatic updates and security checks.
Speed up the basics of IT management
The HP Manageability Integration Kit helps speed up image creation and management of hardware, BIOS, and security through Microsoft System Center Configuration Manager.
Several deployment options
Pair this space-saving AiO with the mounting option to fit your workspace and use case.
Cut out the chatter
Suppress background noise including keyboard clicks with HP Noise Cancellation Software.
HP ProOne 400 G3 - all-in-one - Core i5 7500 3.4 GHz - 4 GB - SSD 256 GB - LED 20" - UK
Personal computer - all-in-one
Intel Core i5 (7th Gen) 7500 / 3.4 GHz (, up to 3.8 GHz, (Quad-Core)
Intel HD Graphics 630 Dynamic Video Memory Technology
Camera
Audio Output
Stereo
1GbE
Keyboard
OS Provided
Windows 10 Home Single Language 64-bit Edition
Software Included
Skype, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP ePrint, HP Hotkey Support, Windows Defender, HP Client Security, HP Systems Software Manager (free download), HP Velocity, HP Secure Erase, HP BIOS Configuration Utility (free download), HP Drive Packs (free download), HP Client Catalogue (free download), HP JumpStart, HP Noise Cancellation, HP BIOSphere Gen3, HP JetAdvantage, HP Manageability & Integration Kit (free download), HP Notifications
49.772 cm x 5.889 cm x 34.751 cm
5.61 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 1 year - on-site
4 x USB 3.1 Gen 1 (2 front, 2 rear) (one of them is fast-charging) , 2 x USB 2.0 (2 rear) (wake functionality) , 1 x DisplayPort , 1 x headphones , 1 x microphone , 1 x audio line-out , 1 x LAN (Gigabit Ethernet) - RJ-45 , 1 x PS/2 keyboard , 1 x PS/2 mouse
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Low halogen
Power adapter
Power Provided
90 Watt
Efficiency
89%
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Windows 10 Home Single Language 64-bit Edition English
Software
Sustainability Information
ENERGY STAR Certified
Dimensions & Weight Details
49.772 cm - 5.889 cm - 34.751 cm - 5.61 kg - without stand
