Complement your HP Pro PC with the HP ProDisplay P202va Monitor, a sleek display that delivers essential presentation features and advanced connectivity for your everyday business productivity at a highly affordable price point.
Be a better consumer with a display that has environmentally responsible components that include low halogen, arsenic-free glass, and mercury-free backlights.
Place it where you need it
Free up valuable desk space with mounting options enabled by the 100-mm VESA pattern, including the HP Adjustable Dual Display Stand, which holds two displays in a single-stand footprint. Select the head-only model if you don't need a stand.
Complete the picture
Customize a total solution with options designed for your display.
Your monitor's new best friend
Design the screen for how you work with HP Display Assistant software.
Global reassurance
Rest assured that your IT investment is supported by a three-year standard limited warranty, and a stable product lifecycle and minimum one-year lifespan. Add HP Care Pack Services to extend your protection beyond the standard limited warranties.
HP ProDisplay P202va - LED monitor - Full HD (1080p) - 19.53"
With stand - width: 47.41 cm - depth: 47.41 cm - height: 35.76 cm - weight: 3.3 kg , Without stand - width: 47.41 cm - depth: 5.3 cm - height: 29.21 cm - weight: 2.6 kg
