Powered for business, the HP ProDesk 600 SFF is a highly expandable PC featuring flexible connectivity options, strong security, and comprehensive manageability features in a stylishly designed chassis for the modern workplace.
Power through your day with Windows 10 Pro with built-in security, collaboration, and connectivity.
Firmware level protection
Protect the firmware that antivirus can't reach! The hardware-enforced self-healing protection offered by HP Sure Start Gen4 automatically recovers the BIOS from malware, rootkits, or corruption.
Browse confidently
Help protect your PC from websites, attachments, malware, ransomware, and viruses with hardware-enforced security from HP Sure Click.
Work without interruption
Keep productivity high and downtime low with HP BIOSphere Gen4 firmware-level automation. Your PCs have extra protection thanks to automatic updates and security checks.
Speed up the basics of IT management
The HP Manageability Integration Kit helps speed up image creation and management of hardware, BIOS, and security through Microsoft System Center Configuration Manager.
Super secure. Super protected
HP Client Security Manager Gen4 features HP Multi-Factor Authenticate, HP Device Access Manager, HP SpareKey, and HP Password Manager. These tools work to keep data out of reach and defend against theft, attacks, and unauthorized users.
HP Recovery Manager, HP Support Assistant, HP Hotkey Support, HP Spare Key, Password Manager, Windows Defender, HP Secure Erase, HP Manageability, HP BIOSphere, HP BIOS Configuration Utility (free download), HP Credential Manager, HP Client Catalogue (free download), HP Driver Packs, HP Device Access Manager, HP JumpStart, HP Noise Cancellation, HP System Software Manager (free download), HP PhoneWise, HP Sure Click, HP BIOSphere Gen4, HP Client Security Suite Gen4, Power On Authentication, HP SureStart Gen4, Ivanti Management Suite, HP Management Integration Kit for Microsoft System Center Configuration Manager Gen 2
9.5 cm x 27 cm x 29.5 cm
4.5 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years - on-site
Personal computer
Product Form Factor
Small form factor
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
Intel Core i5 (8th Gen) 8500
Clock Speed
3 GHz
Max Turbo Speed
4.1 GHz
Number of Cores
6-core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
Processor Main Features
Intel Turbo Boost Technology 2, Intel Smart Cache
CPU Socket
LGA1151 Socket
Chipset Type
Intel Q370
Cache Memory
Installed Size
9 MB
Cache Per Processor
9 MB
RAM
Installed Size
8 GB / 64 GB (max)
DDR4 SDRAM - non-ECC
Effective Memory Speed
2666 MHz
DIMM 288-pin
Slots
4 (Total) / 3 (empty)
Unbuffered
Configuration Features
1 x 8 GB
Hard Drive
HDD
1 x 1 TB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Storage Controller
SATA
Controller Interface Type
SATA 6Gb/s
Optical Storage
DVD-Writer - SATA
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Intel UHD Graphics 630
Video Interfaces
DisplayPort
Audio Output
Sound Output Mode
Stereo
Max Sampling Rate
192 kHz
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
HP Business Slim Keyboard
USB
Localization & Layout
Mouse
Optical
USB
Interface (Bus) Type
PCI Express Mini Card (M.2)
Ethernet Controller
Intel I219-LM
Remote Management Protocol
SNMP 2
Wake on LAN (WoL), ACPI support, PXE support, auto-uplink (auto MDI/MDI-X)
4 x USB 2.0 (2 front, 2 rear) , 1 x USB-C 3.1 Gen 2 (1 in front) , 4 x USB 3.1 Gen 2 (2 front, 2 rear) , 2 x USB 3.1 Gen 1 (2 rear) , 1 x audio line-in , 1 x audio line-out , 2 x DisplayPort , 1 x LAN (Gigabit Ethernet) , 1 x headphones/microphone
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
RoHS, WEEE, low halogen
Power supply
Power Provided
180 Watt
Efficiency
92%
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Windows 10 Pro 64-bit Edition English
Software
Sustainability Information
ENERGY STAR Certified
