The desktop has evolved. Packed with integrated business-class performance and security, this is HP's smallest business desktop yet. Efficiently crafted to save space and energy, the HP Desktop Mini will fit almost any work space.
Smaller than some desk phones, this Desktop Mini can fit almost anywhere vertically or horizontally. The clean, easily serviceable design with integrated wireless antenna allows flexible deployment options to help optimize the workspace.Be up to 35% more productive by adding up to three independent displays using the integrated DisplayPort with Multi-Stream video outputs.Set up the HP ProDesk 600 G1 Desktop Mini in almost any spot or easily attach to several optional peripheral devices using the integrated VESA mount.The HP ProDesk 600 Desktop Mini G1 withstands 115,000 hours of the HP Total Test Process so you get confidence built right in.Easily service the HP ProDesk 600 G1 Desktop Mini. A single thumb screw provides fast access to clearly identifiable and serviceable components.
Full ProDesk functionality
Keep productivity high and downtime low with HP BIOSphere firmware-level automation. Your PCs have extra protection thanks to automatic updates and security checks.Power through your day with speed and performance. Get the latest in processing technology with your choice of 4th generation Intel Core processors.Take advantage of new drive technology with an optional M.2 PCIe solid state hard drive module, the internal 2.5" SSD, or dual drive configurations for more local storage.Make the most of virtual conferencing. Bring work to life through rich sound and video using DTS Studio Sound Audio software.Put in more face time. You're ready for web chats and conferences with Skype pre-configured on your HP ProDesk 600. It's almost as good as being there.
Solid security
HP BIOSphere boosts security and keeps mission-critical data and systems under lock and key with customizable authentication and BIOS-level passwords.HP Secure Erase removes the contents of a hard drive for repurposing or reassignment.Get extra protection with secured storage and ensured platform integrity thanks to the Trusted Platform Module security chip used by the BIOS and the Operating System.Keep sensitive information in safe hands. HP Trust Circles helps protect your data by ensuring that only assigned contacts can access critical files.
Green with envy
The low energy consumption levels of this ENERGY STAR qualified and EPEAT Gold certified PC supports 24/7 operations. Consuming less than 8W of power at idle your Desktop Mini can be always on and always updated.
HP ProDesk 600 G1 - mini desktop - Core i5 4590T 2 GHz - 4 GB - HDD 500 GB - UK - TAA Compliant
Personal computer - mini desktop - administrator password, power-on password, USB port control, DriveLock, Intel Identity Protection Technology (Intel IPT), Setup Password
Intel Core i5 (4th Gen) 4590T / 2 GHz (, up to 3 GHz, (Quad-Core)
Intel HD Graphics 4600 Dynamic Video Memory Technology
Audio Output
Stereo - integrated
1GbE, 802.11a, 802.11b/g/n
Keyboard
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 8.1 Pro) + Windows 8.1 Pro Licence
Software Included
Cyberlink PowerDVD, CyberLink Power2Go, Adobe Flash Player, HP Recovery Disc Creator, Skype, Microsoft Security Essentials, HP Support Assistant, Bing Toolbar, HP ePrint, PDF Complete Corporate Edition, Microsoft Internet Explorer 10, Device Access Manager, HP Client Security, HP PageLift, HP File Sanitizer, Drive Encryption, Box.net, HP Disk Sanitizer External Edition (free download)
17.5 cm x 17.7 cm x 3.4 cm
1.3 kg
TAA Compliant
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years - on-site
Personal computer
Product Form Factor
Mini desktop
Embedded Security
Trusted Platform Module (TPM 1.2) Security Chip
Processor / Chipset
CPU
Clock Speed
2 GHz
Max Turbo Speed
3 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
Processor Main Features
Intel Turbo Boost Technology 2
Chipset Type
Intel Q85
Cache Memory
Installed Size
6 MB
Cache Per Processor
6 MB
RAM
Installed Size
4 GB / 16 GB (max)
DDR3 SDRAM - non-ECC
Effective Memory Speed
1600 MHz
Rated Memory Speed
1600 MHz
Memory Specification Compliance
PC3-12800
SO-DIMM 204-pin
Slots
2 (Total) / 1 (empty)
Unbuffered
Configuration Features
1 x 4 GB
Hard Drive
HDD
1 x 500 GB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x SATA - integrated
Controller Interface Type
SATA 6Gb/s
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Graphics Processor
2 (total) / 1 (free) x SO-DIMM 204-pin , 2 (total) / 1 (free) x M.2 Card , 1 (total) / 0 (free) x CPU
4 x USB 3.0 (2 front, 2 rear) , 2 x USB 2.0 , 1 x VGA , 2 x DisplayPort , 1 x headphones (1 in front) , 1 x microphone (1 in front) , 1 x audio line-out , 1 x LAN (Gigabit Ethernet)
Administrator password, power-on password, USB port control, DriveLock, Intel Identity Protection Technology (Intel IPT), Setup Password
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
ACPI, RoHS, WEEE
TAA Compliant
Power adapter
Power Provided
65 Watt
Efficiency
87%
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8.1 Pro) + Windows 8.1 Pro Licence - English
OS Certified
Red Hat Enterprise Linux, SUSE Linux Enterprise Desktop 11
Software
Sustainability Information
ENERGY STAR Certified
