Give your business the strong foundation it needs for growth with the affordable and reliable HP ProDesk 400 SFF. Designed with essential security and manageability features, the HP ProDesk 400 helps keep your business growing.
New powerful processors
New 6th Gen Intel® Core™ processors bring powerful processing with Intel® HD 530 Graphics. Available DDR4 memory helps meet the demands of today’s businesses.
Security from the start
HP BIOSphere and HP Client Security boost security and keep critical data and systems under lock and key with customizable authentication and BIOS-level passwords.
Tested to go the distance
HP ProDesks are rigorously tested to help ensure reliability. During the HP Total Test Process, PCs experience 120,000 hours of performance trials to help get you through your business day.
Make the smart investment
The HP ProDesk 400 SFF helps affordably build a solid IT infrastructure for your growing business and fits in smaller workspaces for easy deployment.
Windows 10 - Familiar and better than ever
Feels familiar
Windows 10 is the familiar feel of Windows – only better. The Start menu is back and better than ever so you can expand and customize it.
Compatible
With Windows 10 you don't have to replace all your stuff.
More protection. Prompt updates
Windows Update provides more than just security updates and patches. Now you get prompt updates to help you stay current with the latest Windows experience.
Fast and responsive
Technologies like InstantGo* let you boot up and resume quickly. Your apps and the web run speedy-fast because the system balances the memory and processor resources efficiently.
