Give your business the strong foundation it needs for growth with the affordable and reliable HP ProDesk 400 MT. Designed with essential security and manageability features, the HP ProDesk 400 helps keep your business growing.
New 6th Gen Intel Core processors bring powerful processing with Intel HD 530 Graphics. Available DDR4 memory helps meet the demands of today's businesses.
Security from the start
HP BIOSphere and HP Client Security boost security and keep critical data and systems under lock and key with customizable authentication and BIOS-level passwords.
Tested to go the distance
HP ProDesks are rigorously tested to help ensure reliability. During the HP Total Test Process, PCs experience 120,000 hours of performance trials to help get you through your business day.
Make the smart investment
The HP ProDesk 400 MT helps affordably build a solid IT infrastructure for your growing business with scalability in major components that allow you to configure the right PC for each user.
1 (total) / 0 (free) x external 5.25" Slim Line , 1 (total) / 1 (free) x external , 1 (total) / 0 (free) x internal 3.5" , 1 (total) / 1 (free) x internal 2.5" / 3.5" shared
Slots
3 (total) / 3 (free) x PCIe 2.0 x1 - full-height , 1 (total) / 1 (free) x PCIe 3.0 x16 - full-height , 1 (total) / 0 (free) x CPU , 2 (total) / 1 (free) x DIMM 288-pin
4 x USB 3.0 (2 front, 2 rear) , 4 x USB 2.0 , 1 x serial , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x VGA , 1 x DisplayPort , 1 x headphones (1 in front) , 1 x microphone (1 in front) , 1 x audio line-in , 1 x audio line-out , 1 x LAN (Gigabit Ethernet)
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), padlock loop
Security Slot Type
Kensington security slot
ACPI
TAA Compliant
Power supply
80 PLUS Certification
80 PLUS Bronze
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence - English
Limited warranty - parts and labour - 1 year - on-site
