Meet your needs and your budget with a reasonably priced business desktop with optional bundled displays ready for expansion and upgrades.
Designed with work in mind
The newly designed HP ProDesk 400 G2 MT provides easy access to components through the tool-less chassis, front USB 3.0 ports for quick connections and support for legacy ports to support your business.
Perform at the speed of work
Enjoy the business ready performance of the 4th generation Intel Core processors equipped with a powerful chipset, processor support and robust memory.
Safeguard data and devices
Help keep sensitive data secure with comprehensive security features like HP Client Security and HP BIOS Protection.
Guard your data, device and identity with HP Client Security.HP BIOS Protection's automated recovery restores a copy of the BIOS from a partition on the hard drive if crisis strikes.Rest easy with a ProDesk that endures 115,000 hours of testing to help ensure reliability in the most demanding work environments.Rest easy and work confidently with dependable support options including a parts/labor/on-site limited warranty and parts availability for up to 5 years.Optional HP Care Pack with Accidental Damage Protection helps you avoid out-of-pocket repair or replacement costs and delivers service right to your door.
Intel HD Graphics 4600 Dynamic Video Memory Technology
Audio Output
Stereo - integrated
GigE
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 8.1 Pro) + Windows 8.1 Pro Licence
Software Included
Cyberlink PowerDVD, CyberLink Power2Go, HP Recovery Disc Creator, Skype, Microsoft Security Essentials, HP Recovery Manager, HP Support Assistant, HP ePrint, Foxit PhantomPDF Express, Password Manager, HP Client Security, Device Access Manager with Just In Time Authentication, HP PageLift, Box.net 50GB storage, Drive Encryption, HP Disk Sanitizer External Edition (free download)
16.5 cm x 35.88 cm x 35.5 cm
6.5 kg
TAA Compliant
Limited warranty - parts and labour - 1 year - on-site
Personal computer
Recommended Use
Small business, corporate business
Product Form Factor
Micro tower
Built-in Devices
Speaker
Processor / Chipset
CPU
Intel Core i5 (4th Gen) 4590S
Clock Speed
3 GHz
Max Turbo Speed
3.7 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
Processor Main Features
Intel Turbo Boost Technology 2
Chipset Type
Intel H81
Cache Memory
Installed Size
6 MB
Cache Per Processor
6 MB
RAM
Installed Size
4 GB / 16 GB (max)
DDR3 SDRAM - non-ECC
Effective Memory Speed
1600 MHz
Rated Memory Speed
1600 MHz
Memory Specification Compliance
PC3-12800
DIMM 240-pin
Slots
2 (Total) / 1 (empty)
Unbuffered, dual channel memory architecture
Configuration Features
1 x 4 GB
Hard Drive
HDD
1 x 500 GB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x SATA - integrated
Controller Interface Type
SATA 6Gb/s
Optical Storage
DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Graphics Processor
Video Interfaces
VGA, DVI
HDCP Compatible
Max Monitors Supported
2
Audio Output
Integrated
Sound Output Mode
Stereo
Max Sampling Rate
192 kHz
High Definition Audio, DTS SOUND+
Integrated
Ethernet Controller
Realtek RTL8151GH-CG
Wake on LAN (WoL), PXE support, auto-uplink (auto MDI/MDI-X)
1 (total) / 0 (free) x external 5.25" Slim Line , 2 (total) / 1 (free) x internal 3.5"
Slots
1 (total) / 1 (free) x PCIe 3.0 x16 - full-height , 3 (total) / 3 (free) x PCIe 2.0 x1 - full-height , 1 (total) / 0 (free) x CPU , 2 (total) / 1 (free) x DIMM 240-pin
4 x USB 2.0 , 2 x USB 3.0 (2 in front) , 1 x serial , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x VGA , 1 x DVI-D , 1 x microphone (1 in front) , 1 x headphones (1 in front) , 1 x audio line-in , 1 x audio line-out , 1 x LAN (Gigabit Ethernet)
Administrator password, power-on password, hard drive I/O control, serial port I/O control, USB port control
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
ACPI, RoHS, WEEE
TAA Compliant
Power supply
Power Provided
180 Watt
80 PLUS Certification
80 PLUS Bronze
Efficiency
85%
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8.1 Pro) + Windows 8.1 Pro Licence
Software
