Maximize your mobile productivity with the HP Pro Tablet 408 Active Pen, which allows you to write naturally on your HP Pro Tablet 408 G1 screen and navigate touchscreen activities.
Use the pen to write or draw onscreen or interact with your touch applications. Integrated pressure sensors help you control the width of your drawn lines.
Easy to use
Once in range, your tablet detects the pen and cues you where to place it onscreen. Erase, highlight, and click on your content with the two convenient side buttons.
World-class support
Rest easy with a one-year limited warranty.
HP Active Pen - digital pen
Digital pen
0.98 cm x 0.98 cm x 14.55 cm
25 g
AAAA type
Windows 8 / 8.1
1-year warranty
Pro Tablet 10 EE G1, 408 G1; Spectre Pro x360 G2; x2 210, 210 G2
Digital pen
0.98 cm
0.98 cm
14.55 cm
25 g
AAAA battery
AAAA type
Windows 8 / 8.1
Limited warranty - 1 year
HP Pro Tablet 10 EE G1, 408 G1 , HP Spectre Pro x360 G2 , HP x2 210, 210 G2
