Work seamlessly with the HP Pro Slate 12, which runs Android Lollipop with native Work Profiles, a feature of Android for Work, and has hardware-enabled security, a Qualcomm Snapdragon 800 series processor, and an integrated HP Duet Pen.
Help protect your tablet with device authentication and tamper-resistant features.
Enterprise-friendly
Customize your enterprise mobility solution with HP Managed Mobility Services.
Cloud-based IT management made simple
Manage data, security, and a wide array of branded devices from the cloud with HP Touchpoint Manager. Use Locate Device to remotely locate, lock, and wipe your tablet.
Ready for your environment
Easily integrate your devices with optional, leading EMM solutions.
Excel with built-in extras
Do more with up to 32 GB storage, micro USB 2.0 connectivity, and integrated communication tools.
Functional for business
Go business-class all the way with innovative optional accessories that connect easily with a zero-force, Pogo pin connector. Make it yours with a choice of adapters, HP Bluetooth Keyboard Folio or HP Paper Folio for use with the HP Duet Pen.
HP Pro Slate 12 - tablet - Android 4.4.4 (KitKat) - 32 GB - 12.3" - 4G - service not included
Skype, Evernote, Secure Boot, Kingsoft Office, Corel Painter Mobile, HP Print, Avast Mobile Security, HP TouchPoint Manager, HP Notes, HP Duet Pen Software
Expansion and Connectivity
Expansion Slots
1 x microSD , 1 x Nano-SIM card , 1 x ZIF
1 x headset mini jack (3.5mm) , 1 x Micro-USB , 1 x HDMI (supporting via optional adapter)
Lithium polymer
37 Wh
Run Time
Up to 14.75 hours
Run Time Details
Video playback: up to 14.75 hour(s)
Grey
Sensors
Accelerometer, ambient light sensor, proximity sensor, digital compass, barometer, gyro sensor, hall sensor
Power adapter, stylus, SD/SIM card tray eject tool
Micro-USB to USB cable
CSA, UL, CISPR 24, EN55022, ICES-003, EN55024, CISPR 22, CB, RSS-102, EMC, IC, FCC, FIPS 140-2, FCC CFR47 Part 15, EN 60950-1, EN 301 908, EN 62311, EN 300.440, EN 300 328, EN 301 489, EN 301 893
English / United Kingdom
22.195 cm
0.799 cm
30.03 cm
850 g
Limited warranty - 1 year , Limited warranty - battery - 1 year
