Customize a professional desktop solution by connecting your tablet to an external display, wired network, and your everyday devices with HDMI, RJ-45, USB, and audio ports.
Easy portability
Take your dock and go. The compact size fits easily in a carrying case alongside your tablet.
Charge up
Set the tablet in the dock to charge its battery while you work. The recessed tablet holder slot has a 105-degree viewing angle so you can comfortably interact with the screen.
HP Pro Portable Dock - docking station - HDMI - 10Mb LAN
Docking station
Video Interfaces
HDMI
11 cm x 10 cm x 1.9 cm
233 g
Ethernet
Power adapter
1-year warranty
Pro Slate 12, 8; Pro Tablet 608 G1
Docking station
11 cm
10 cm
1.9 cm
233 g
Enclosure Colour
Ethernet
1 x USB 2.0 - 4 pin USB Type A , 1 x audio / video - HDMI - 19 pin HDMI Type A , 1 x headphones - output - mini-phone stereo 3.5 mm , 1 x network - Ethernet - RJ-45
