Get creative and print lab-quality photos via the large touchscreen and auto-engaging photo paper tray. Print and share however you choose, wirelessly or with HP ePrint mobile printing – now you can print from virtually anywhere..
Print brilliant, lab-quality photos without a PC via the large touchscreen
Print lab-quality photos – scan and copy too – directly from the large and intuitive touchscreen.Switch between everyday and photo paper or other media using the auto-engaging photo paper tray.Connect to online photo libraries without a PC or print direct from memory card.Enjoy affordable printing with individual inks; optional XL cartridges for frequent printing.
Create impressive everyday projects via web-based apps, two-sided printing and more
Save time and paper with reliable, automatic two-sided printing – great for creative projects.Access easy-to-use apps and print Sudoku puzzles, colouring pages and more – all without a PC.Choose HP Quick Forms and print templates such as calendars, games and notebook pages.Do it all from the large, easy-to-use colour touchscreen – print, copy, scan and create, even access web content.
HP Photosmart 6510 e-All-in-One B211a - multifunction printer - colour
Multifunction printer
Copier Type
Digital
Printing Technology
Ink-jet (colour)
Inkjet Technology
HP Thermal Inkjet - 4-ink
Monthly Duty Cycle (max)
1000 impressions
Max Copying Speed
Up to 6.5 ppm (mono) / up to 5.5 ppm (colour)
Max Copying Resolution
Up to 600 dpi (mono) / up to 600 dpi (colour)
Max Printing Speed
Up to 11 ppm (mono) / up to 7.5 ppm (colour)
Max Printing Resolution
Up to 1200 x 600 dpi (mono) / up to 4800 x 1200 dpi (colour)
Scanning
1200 x 1200 dpi
Original Size
216 x 297 mm (max)
Media Size
76 x 127 mm (min) - Legal (216 x 356 mm) (max)
Media Type
Transparencies, envelopes, plain paper, cards, labels, photo paper
Standard Media Capacity
80 sheets
Output Trays Capacity
20 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
USB 2.0, Wi-Fi(n)
Office Machine Features
Print from memory card
AC 110/230 V (50/60Hz)
43.6 cm x 38.1 cm x 16.1 cm
5.6 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
Copier Type
Digital
Printing Technology
Ink-jet - colour - photo
1000 impressions
Display Features
Touch screen
USB 2.0, Wi-Fi(n)
Standard Memory
64 MB 64 MB
Max Supported Memory
64 MB 64 MB
Supported Flash Memory
SD Memory Card, MultiMediaCard, Memory Stick Duo
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
50
Printing
Inkjet Technology
HP Thermal Inkjet
Supported Media Sizes
Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, C6 (114 x 162 mm), 76 x 127 mm, 100 x 300 mm, 110 x 220 mm
Printing: up to 11 ppm - B/W best , Printing: up to 7.5 ppm - colour best , Copying: up to 6.5 ppm - B/W best , Copying: up to 5.5 ppm - colour best
1 x USB 2.0
Operating System Support
MS Windows XP SP2 or later, Apple Mac OS X 10.5, MS Windows 7, MS Windows Vista, Apple Mac OS X 10.6, Apple Mac OS X 10.7
Software Included
HP Photo Creations
13 Watt
Power Consumption Standby
5.1 Watt
Power Consumption Sleep
2.7 Watt
Consumables Included
1 x ink cartridge (black) - HP 364 , 1 x ink cartridge (cyan) - HP 364 , 1 x ink cartridge (magenta) - HP 364 , 1 x ink cartridge (yellow) - HP 364
