Faster than any colour MFP in its class, HP PageWide delivers professional-quality colour documents, fast two-sided scanning, and best-in-class energy efficiency – all at a low purchase price.
Results you expect, lasting value, and a low total cost of ownership.Print professional-quality colour on a variety of papers – perfect for office use.Spend less time and budget on scheduled maintenance with streamlined HP PageWide Technology.
The fastest MFP in its class
Wait less, do more with unmatched speeds – up to 45 ppm – and the fastest first-page printing in its class.Get fast two-sided scanning directly to email and the cloud.Manage tasks from a 10.9 cm (4.3-inch) touchscreen. Easily print PDF and JPEG files from a USB drive.Print from your mobile device with Wi-Fi Direct and NFC touch-to-print technology – no network needed.
Proven technology
Minimise downtime with HP PageWide Technology that delivers reliable performance businesses demand.Conserve with HP PageWide Technology – designed to use less energy than any MFP in its class.Get professional-quality colour documents and the performance you expect with Original HP PageWide cartridges.
HP PageWide MFP 377dw - multifunction printer - colour
Multifunction printer
Fax Type
Plain paper
EMEA (excluding Israel, Saudi Arabia, South Africa)
Printing Technology
Page wide array (colour)
Inkjet Technology
4-ink
Monthly Duty Cycle (max)
40000 pages
Recommended Monthly Volume
500 - 3000 pages
Max Copying Speed
Up to 30 ppm (mono) / up to 30 ppm (colour)
Max Copying Resolution
Up to 600 dpi (mono) / up to 600 dpi (colour)
Max Printing Speed
Max Printing Resolution
Up to 1200 x 1200 dpi (mono) / up to 2400 x 1200 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
203 x 98 dpi, 203 x 196 dpi, 300 x 300 dpi, 200 x 200 dpi
Scanning
1200 x 1200 dpi
Display
4.3"
Original Size
Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Print from USB flash drive, save to USB flash drive, scan to e-mail, scan to folder, scan to network, HP EasyColor, Mobile Printing, access point mode, scan to SharePoint, scan to PC, scan to OCR
AC 120/230 V (50/60Hz)
53 cm x 40.7 cm x 46.7 cm
22.15 kg
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Fax Type
Plain paper
Printing Technology
Page wide array - colour
40000 pages
500 - 3000 pages
Display Diagonal Size
4.3"
Display Features
Touch screen
Connection Availability
USB 2.0, LAN, Wi-Fi(n), NFC, USB 2.0 host
AirPrint Enabled
Office Machine Features
Standard Memory
768 MB
Max Supported Memory
768 MB
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Automatic Duplexing
Copying Features
ID Card Copy, collation copy
Printing
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), 101.6 x 152.4 mm, Statement (139.7 x 215.9 mm), 127 x 178 mm, 76.2 x 127 mm, Oficio (216 x 343 mm)
Supported Envelope Sizes
US No 10 (104.7 x 241.3 mm)
Standard Media Capacity
500 sheets
Output Trays Capacity
300 sheets
ADF - 50 sheets size: 101.6 x 210.8 mm - 215.9 x 297.2 mm , Input tray - 500 sheets size: 76.2 x 127 mm - 215.9 x 355.6 mm , Output tray - 300 sheets
Speed Details
Scanning: up to 25 ipm (A4) - B/W , Scanning: up to 25 ipm (A4) - colour , Printing: up to 45 ppm (A4) - B/W draft , Printing: up to 45 ppm (A4) - colour draft , Printing: up to 30 ppm - B/W (ISO) , Printing: up to 30 ppm - colour (ISO) , Copying: up to 45 ppm (A4) - B/W draft , Copying: up to 45 ppm (A4) - colour draft , Copying: up to 30 ppm - B/W (ISO) , Copying: up to 30 ppm - colour (ISO) , Printing: up to 45 ppm (Letter A) - B/W draft , Printing: up to 45 ppm (Letter A) - colour draft , Copying: up to 45 ppm (Letter A) - B/W draft , Copying: up to 45 ppm (Letter A) - colour draft
2 x modem - RJ-11 , 1 x LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B , 2 x USB 2.0 host - 4 pin USB Type A
UNIX, Novell NetWare 6, Linux, MS Windows 7, Novell NetWare 6.5, Apple Mac OS X 10.6, MS Windows Server 2008 R2, MS Windows Server 2012, Windows 8, Novell Open Enterprise Server, MS Windows Server 2003 (32/64-bits), MS Windows Server 2003 R2 (32/64-bits), MS Windows Small Business Server 2003 (32/64 bits), MS Windows Server 2008 (32/64-bits), MS Windows Small Business Server 2008 x64 Edition, MS Windows XP 32-bit Edition SP3 or later, Windows 10, MS Windows Vista 32-bit Edition
Software Included
Drivers & Utilities, I.R.I.S. OCR, HP Web Jetadmin, HP Participation Study
100 watt
Power Consumption Standby
9.5 watt
Power Consumption Sleep
4.5 watt
Phone cable
Consumables Included
1 x ink cartridge (black) - up to 3000 pages - HP 913 , 1 x ink cartridge (cyan) - HP 913 , 1 x ink cartridge (magenta) - HP 913 , 1 x ink cartridge (yellow) - HP 913
ENERGY STAR Certified
Limited warranty - parts and labour - 1 year - on-site , Technical support - phone consulting - 1 year
