Tackle your daily to-do list and multi-task across multiple windows on the extra-large 27" diagonal HP P27v G4 Monitor that adjusts to your comfort needs and delivers Full HD picture quality with clear 178° sightlines.
Choose a monitor that's TCO and ENERGY STAR certified to help meet your environmental buying requirements.
Personalize your comfort settings
See your screen in a whole new light with HP Low Blue Light, which shifts the color spectrum for more comfortable viewing. Tilt the screen up to 5° forward or 20° back to find your best viewing position.
We have your back
Rest assured that your IT investment has a long lifecycle and is supported with our three-year standard limited warranty. To extend your protection, select an optional HP Care Pack service.
HP P27v G4 - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/458124
Energy Class
Class E
Energy Consumption per Year
32 kWh
Power Consumption (On mode)
20.4 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.3114 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 8000000:1 (dynamic)
Response Time
5 ms (On/Off)
Colour Gamut
72% NTSC
Input Connectors
HDMI, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, 3H Hard Coating, Haze 25%
Voltage
AC 100-240 V (50/60 Hz)
61.22 cm x 20.01 cm x 44.77 cm
4.5 kg
English / United Kingdom
Environmental Standards
ENERGY STAR Qualified
VCCI, C-Tick, BSMI, CB, CCC, PSB, FCC, ISO 9241-307, KCC, Energy-using Products (EuP) Lot 6, WEEE, ICES, cTUVus, MEPS, TUV Bauart, E-Standby, CEC, UkrSEPRO, KC, CECP, CEL, EAC, ISC, SEPA, BIS, Energy-using Products (EuP) Lot 5, CE/EMC, NOM-NYCE, Australian-New Zealand MEPS, Vietnam MEPS, South Africa MEPS, Ukraine Energy Label, TGM, Japan PC Green Label
3-year warranty
Display Type
Energy Class
Class E
32 kWh
Diagonal Size
27"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.3114 mm
Pixel Per Inch
81.59
Brightness
300 cd/m²
Contrast Ratio
Colour Gamut
72% NTSC
Response Time
5 ms (On/Off)
Vertical Refresh Rate
50 - 60 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
Low Blue Light Mode, Color Calibrated, 3-sided micro-edge, 72% NTSC colour gamut
Security Slot Type
Kensington security slot
Input Voltage
20.4 W
20.4 kWh/1000h
Power Consumption (Typical)
28 watt
Power Consumption Stand by
0.5 watt
Dimensions & Weight Details
With stand - width: 61.22 cm - depth: 20.01 cm - height: 44.77 cm - weight: 4.5 kg , Without stand - width: 61.22 cm - depth: 4.77 cm - height: 36.77 cm - weight: 4 kg
