Boost team efficiency with this high productivity, next generation wireless MFP. Print professional-quality colour at up to half the cost per page and twice the speed of colour lasers using HP PageWide Technology.
Give workgroups the power to do more with this easy-to-manage MFP
Tap and swipe the large colour touchscreen to print, copy, scan, fax and send digital files.Remotely and easily manage your entire fleet with HP Web Jetadmin and HP's Universal Print Driver.Future-proof your investment with expandable HP JetAdvantage and partner solutions.Protect data via PIN printing with USB memory. Authorise access to device capabilities and colour printing.
Get an MFP built for business performance you can rely on
In durability testing performed by Buyers Lab, over 150,000 pages were printed without jams or failure.Print from your smartphone or tablet from virtually anywhere with HP ePrint.Print up to 9,200 pages per cartridge and load up to 1,050 sheets at once with the optional paper tray.
Conserve resources without sacrificing performance
Control your costs – ENERGY STAR qualified device uses up to 50% less energy than colour lasers.Save up to 50% on paper with automatic two-sided printing, and maintain efficiency at breakthrough speeds.Reduce your impact – easily recycle your Original HP ink cartridges for free through HP Planet Partners.
HP Officejet Pro X576dw MFP - multifunction printer - colour
Multifunction printer
Fax Type
Plain paper
Printing Technology
Ink-jet (colour)
Inkjet Technology
HP PageWide - 4-ink
Monthly Duty Cycle (max)
75000 impressions
Recommended Monthly Volume
1000 - 4200 pages
Max Copying Speed
Up to 42 ppm (mono) / up to 42 ppm (colour)
Max Copying Resolution
Up to 600 dpi (mono) / up to 600 dpi (colour)
Max Printing Speed
Max Printing Resolution
Up to 1200 x 1200 dpi (mono) / up to 2400 x 1200 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
203 x 98 dpi, 203 x 196 dpi, 300 x 300 dpi, 200 x 200 dpi
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, JIS B5 (182 x 257 mm), 101.6 x 152.4 mm, Statement (139.7 x 215.9 mm), B6 (125 x 176 mm), 76.2 x 127 mm, 127 x 177.8 mm, Oficio (216 x 343 mm), 215.9 x 330.2 mm, JIS B6 (128 x 182 mm)
Supported Envelope Sizes
US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm), Japanese Chou No 3 (120 x 235 mm), Japanese Chou No 4 (90 x 205 mm)
Printing: up to 70 ppm - B/W draft , Printing: up to 70 ppm - colour draft , Printing: up to 42 ppm - B/W (ISO) , Printing: up to 42 ppm - colour (ISO) , Copying: up to 70 ppm - B/W draft , Copying: up to 70 ppm - colour draft , Copying: up to 42 ppm - B/W (ISO) , Copying: up to 42 ppm - colour (ISO) , Scanning: up to 20 ppm - B/W , Scanning: up to 15 ppm - colour
2 x USB host - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
Security Protocols & Features
SSL, LEAP, TLS
Operating System Support
Linux, MS Windows 7, MS Windows XP SP3, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows Vista (64-bit versions), Apple Mac OS X 10.6, Apple Mac OS X 10.7, Apple Mac OS X 10.8, Windows 8
Software Included
Drivers & Utilities, HP ePrint Wireless Direct
AC 110/230 V (50/60Hz)
100 Watt
Power Consumption Standby
9.5 Watt
Power Consumption Sleep
4.5 Watt
Compatible with Windows 7
