| Quicklinx: | G5F1WS00 |
| Mfr#: | 1KR50B#BHC |
A revolutionary smart printer that works the way you need. Help save time with Smart Tasks shortcuts and get automatic two-sided scanning, easy mobile printing, seamless connections, and best-in-class security. Save up to 70% on ink.
Dynamic security enabled printer
Certain HP printers are intended to work only with cartridges that have a new or reused HP chip or electronic circuitry. These printers use dynamic security measures to block cartridges using a non-HP chip or electronic circuitry. Periodic firmware updates will maintain the effectiveness of these measures and block cartridges that previously worked. Reused HP chips and electronic circuitry enable the use of reused, remanufactured, and refilled cartridges.
http://www.hp.com/learn/ds.
