| Quicklinx: | 7WBHWS00 |
| Mfr#: | CM750A#BEV |
HP Office Inkjet All-in-One Printers deliver professional colour and black-and-white documents at a low cost per page, plus a full range of copy and scan tools with advanced paper-handling options.
Print professional documents at up to 50% less cost-per-page than lasers. Equipped with HP ePrint, you can create your own customized email address and print from virtually anywhere with any email-capable device. Also use business apps to access content directly from the web without a PC. It has a low cost-per-page with available high-capacity ink cartridges that offer a better value for frequent printing. It also features a 50-sheet automatic document feeder with 2-sided copy, scan, fax and direct digital filing features such as scan to email, scan to network folder and scan to the web.
Professional color for a lower cost than lasers.
- Print professional color for up to 50% lower cost per page than lasers, and get a better value for frequent printing.[4]
- Print documents that resist fading, water and highlighter-pen smears, using HP Officejet inks.[2][3]
- Achieve ISO print speeds up to 20 ppm black and 16 ppm color,[5] using affordable, individual inks.
- Depend on a printer with a 25,000-page monthly duty cycle--the perfect fit for reliable color printing.
Efficient Web connectivity--even print on the go.[6]
- Print from a variety of mobile devices on the go. With HP ePrint--now you can print from virtually anywhere.[6]
- Use the large touchscreen with gesturing to access business apps, plus quickly print and store files.
- Easily view and print photos from a USB drive and memory cards.
- Stay connected--share on a wireless or wired network.[7]
Standout versatility with copy and scan solutions.
- Create flawless copies with CopySmart solutions, and easily print two-sided identification cards.
- Do more with automatic two-sided print, copy and scan capabilities and the 50-page automatic document feeder.
- Improve workflow--send quick faxes, scan up to legal-size documents to a PC or e-mail, and more.
- Create borderless, double-sided flyers and brochures, plus print impressive business photos.
Exceptional energy and resource savings.
- Use up to 50% less energy than lasers with this ENERGY STAR® qualified printer, and preset On or Off times.
- Easily recycle cartridges, and use up to 70% less supplies and packaging by weight compared with lasers.
- Consume up to 50% less paper while printing, using automatic two-sided printing.
- Use Original HP ink cartridges for quality, reliability and rewards.
[2]Based on paper-industry predictions for acid-free papers and Original HP inks; colorant stability data at room temperature based on similar systems tested per ISO 11798 and ISO 18909.
[3]Based on HP internal testing, using paper with the ColorLok® logo.
[4]Compared with the HP Officejet 950/951 Black and color ink cartridges. For more information, see http://www.hp.com/go/learnaboutsupplies. High-capacity cartridges not included; please purchase separately.
[5]After first set of ISO test pages. For more information, see http://www.hp.com/go/printerclaims.
[6]Requires an Internet connection to the printer. Feature works with any connected Internet- and e-mail-capable device. Print times may vary. Some HP LaserJets may require a firmware upgrade. For a list of supported documents, and image types, see http://www.hp.com/go/eprintcenter. And for additional solutions see http://www.hp.com/go/mobile-printing-solutions.
[7]Wireless performance is dependent upon physical environment and distance from access point. Wireless operations compatible with 2.4 GHz routers only.
ENERGY STAR® qualified models; see http://www.hp.com/go/energystar
[1] Either after first page or after first set of ISO test pages. For details see http://www.hp.com/go/printerclaims
[2] Power measurements are based on ENERGY STAR® OM test procedure with 230 VAC, 50 Hz input.
[3] Average based on ISO/IEC 24711 or HP testing methodology and continuous printing. Actual yield varies considerably based on content of printed pages and other factors. Some ink from included cartridge is used to start up the printer. For details see http://www.hp.com/go/learnaboutsupplies
