| Quicklinx: | 7WBGWS00 |
| Mfr#: | CM749A#BEV |
Produce professional color for less than lasers page after page, and accelerate productivity with apps on the large touchscreen, networking options and versatile e-all-in-one performance. Easily print from a mobile device with HP ePrint.[6]
Professional color for a lower cost than lasers.
- Print professional color for up to 50% lower cost per page than lasers, and get a better value for frequent printing.[4]
- Print documents that resist fading, water and highlighter-pen smears, using HP Officejet inks.[2][3]
- Achieve ISO print speeds up to 18 ppm black and 13 ppm color, using affordable, individual inks.[5]
- Depend on a printer with a 25,000-page monthly duty cycle--the perfect fit for reliable color printing.
Efficient Web connectivity--even print on the go.[6]
- Print from a variety of mobile devices on the go. With HP ePrint--now you can print from virtually anywhere.[6]
- Use the intuitive touchscreen to access business apps, plus quickly print and store files.
- Easily view and print photos from a USB drive and memory cards.
- Stay connected--share on a wireless or wired network.[7]
Standout versatility with copy and scan solutions.
- Create flawless copies with CopySmart solutions, and easily print two-sided identification cards.
- Automatically print two-sided documents, and decrease intervention with the 250-sheet paper tray.
- Improve workflow--send quick faxes, scan documents to a PC or e-mail, and more.
- Create borderless, double-sided flyers and brochures, plus print impressive business photos.
Exceptional energy and resource savings.
- Use up to 50% less energy than lasers with this ENERGY STAR® qualified printer, and preset On or Off times.
- Easily recycle cartridges, and use up to 70% less supplies and packaging by weight compared with lasers.
- Consume up to 50% less paper while printing, using automatic two-sided printing.
- Use Original HP ink cartridges for quality, reliability and rewards.
[2]Based on paper-industry predictions for acid-free papers and Original HP inks; colorant stability data at room temperature based on similar systems tested per ISO 11798 and ISO 18909.
[3]Based on HP internal testing, using paper with the ColorLok® logo.
[4]Compared with the HP Officejet 950/951 Black and color ink cartridges. For more information, see http://www.hp.com/go/learnaboutsupplies. High-capacity cartridges not included; please purchase separately.
[5]After first set of ISO test pages. For more information, see http://www.hp.com/go/printerclaims.
[6]Requires an Internet connection to the printer. Feature works with any connected Internet- and e-mail-capable device. Print times may vary. Some HP LaserJets may require a firmware upgrade. For a list of supported documents, and image types, see http://www.hp.com/go/eprintcenter. And for additional solutions see http://www.hp.com/go/mobile-printing-solutions.
[7]Wireless performance is dependent upon physical environment and distance from access point. Wireless operations compatible with 2.4 GHz routers only.
[13]Availability of rewards varies by country. For more information, see http://www.hp.com/go/learnaboutsupplies
