Easily print on a variety of paper sizes up to 29.7 x 42 cm (A3). Produce professional-quality colour for up to 50% less cost per-page than lasers on a printer that's ready for business.
Print up to 29.7 x 42 cm (A3). Scan and copy up to legal size.The HP OfficeJet Pro 7720 comes from the same family as the iF Design Award 2017 winner HP OfficeJet Pro 7740.Breeze through tasks with the 35-page automatic document feeder, and get automatic two-sided printing.Take control of print, scan, copy, and fax jobs, using the colour touchscreen and timesaving shortcuts.
Present professionally
Print up to 3x as many black-text and 2x as many colour pages, with optional HP high-yield ink cartridges.Create vibrant colour graphics and black text, ideal for brochures, presentations, and other office documents.Produce water-, smear-, and fade-resistant prints that stand up to highlighters.Create borderless brochures, flyers, photos, and other documents that look great – right in your office.
Easy mobile printing with HP Smart app
Easily print from a variety of smartphones and tablets.Connect your smartphone or tablet directly to your printer – and easily print without accessing a network.Get the power of your printer in the palm of your hand, with the HP Smart app.Simply tap the print button on your smartphone or tablet to print.
HP Officejet Pro 7720 Wide Format All-in-One - multifunction printer - colour
Multifunction printer
Fax Type
Plain paper
EMEA (excluding Israel, Saudi Arabia, South Africa)
Printing Technology
Ink-jet (colour)
Inkjet Technology
HP Thermal Inkjet - 4-ink
Monthly Duty Cycle (max)
30000 pages
Recommended Monthly Volume
250 - 1500 pages
Max Copying Speed
Up to 18 ppm (mono) / up to 13 ppm (colour)
Max Copying Resolution
Up to 600 dpi (mono) / up to 600 dpi (colour)
Max Printing Speed
Up to 22 ppm (mono) / up to 18 ppm (colour)
Max Printing Resolution
Up to 1200 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
203 x 98 dpi, 203 x 196 dpi, 300 x 300 dpi, 200 x 200 dpi
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A3 (297 x 420 mm), 100 x 150 mm, JIS B5 (182 x 257 mm), 101.6 x 152.4 mm, 297 x 431.8 mm, Tabloid (279 x 432 mm)
Standard Media Capacity
250 sheets
Output Trays Capacity
75 sheets
ADF - 35 sheets size: 76 x 127 mm - 216 x 356 mm ¦ Input tray - 250 sheets - A3 (297 x 420 mm) weight: 60 g/m² - 105 g/m² ¦ Output tray - 75 sheets
Speed Details
Printing: up to 34 ppm (A4) - B/W draft , Printing: up to 22 ppm - B/W (ISO) , Printing: up to 34 ppm (A4) - colour draft , Printing: up to 18 ppm - colour (ISO) , Copying: up to 34 ppm (A4) - B/W draft , Copying: up to 34 ppm (A4) - colour draft , Copying: up to 34 ppm (Letter A) - B/W draft , Copying: up to 34 ppm (Letter A) - colour draft , Printing: up to 34 ppm (Letter A) - B/W draft , Printing: up to 34 ppm (Letter A) - colour draft
1 x LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B , 2 x modem - RJ-11 , 1 x USB host - 4 pin USB Type A
Security Protocols & Features
Apple Bonjour, WEP, WPA, AES
Operating System Support
Apple Mac OS X 10.9, MS Windows 7 (32/64 bits), Apple Mac OS X 10.10, MS Windows XP 32-bit Edition SP3 or later, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows 10 (32/64-bits), Apple Mac OS X 10.11, MS Windows Vista 32-bit Edition
Software Included
HP Photo Creations, HP Update, Google Toolbar, Software HP Printer
