Produce professional-quality colour documents with the lowest cost per page compared with in-class inkjet all-in-ones with this network-ready HP e-All-in-One. Fax, copy and scan too, and print from mobile devices with HP ePrint.
Print professional documents with lowest-cost-in-class colour
Print professional-quality colour documents for the lowest cost per page compared with in-class all-in-ones.Get great value with individual inks – high capacity XL ink cartridges available for frequent printing.Save on external print costs too – create vivid, high impact marketing materials with HP Officejet inks.Produce borderless flyers and brochures with rich colour graphics using brochure or photo paper.Use up to 40% less energy tan with colour lasers.
Share high productivity features across multiple PCs on your Ethernet network
Print at speeds equivalent to a laser printer with up to 10 ppm black/7 ppm colour; draft speeds up to 32 ppm black/31 ppm colour.Share the performance across your Ethernet network, or connect directly with Hi-speed USB 2.0.Boost productivity with a 250-sheet paper tray and 35-sheet automatic document feeder.
HP Officejet 6500A e-All-in-One E710a - multifunction printer - colour
Multifunction printer
Copier Type
Digital
Fax Type
Plain paper
Printing Technology
Ink-jet (colour)
Inkjet Technology
HP Thermal Inkjet
Monthly Duty Cycle (max)
7000 impressions
Recommended Monthly Volume
100 - 800 pages
Max Copying Speed
Up to 32 ppm (mono) / up to 31 ppm (colour)
Max Copying Resolution
Up to 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
Max Printing Speed
Max Printing Resolution
Up to 600 dpi (mono) / up to 4800 x 1200 dpi (colour)
Fax Resolutions
300 x 300 dpi
Scanning
4800 x 4800 dpi
Display
2.4"
Original Size
A4 (210 x 297 mm) (max)
Original Type
Sheets
Document Feeder Capacity
35 sheets
Media Size
ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm) (max)
A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 216 x 762 mm, C5 (162 x 229 mm), JIS B5 (182 x 257 mm), C6 (114 x 162 mm), B6 (125 x 176 mm), 76 x 127 mm, 216 x 355 mm
Copying: up to 32 ppm - B/W , Copying: up to 31 ppm - colour draft , Printing: up to 32 ppm - B/W draft , Printing: up to 31 ppm - colour draft
1 x USB 2.0 , 1 x LAN
Operating System Support
Linux, MS Windows 7, Apple Mac OS X 10.6.x, Apple Mac OS X 10.5.8, MS Windows Vista, MS Windows XP SP2
AC 110/230 V (50/60Hz)
36.6 Watt
Power Consumption Standby
5 Watt
Power Consumption Sleep
3.2 Watt
Consumables Included
1 x ink cartridge (black) - up to 420 pages - HP 920 , 1 x ink cartridge (cyan) - up to 300 pages - HP 920 , 1 x ink cartridge (magenta) - up to 300 pages - HP 920 , 1 x ink cartridge (yellow) - up to 300 pages - HP 920
Compatible with Windows 7
