Accomplish your productivity with an easy way to print from your smartphone or tablet. Fly through tasks with an all-in-one with fax, automatic document feeder, and wireless.
Save on ink and never run out. Print photos or documents for the same low price. Print up to twice as many pages or photos with HP ink cartridges. Get high-quality prints - time after time - with an all-in-one designed and built to be reliable.
Easy printing from mobile devices
Easily print documents and photos from a variety of smartphones and tablets. Start printing and get connected quickly with easy setup from your smartphone, tablet, or PC. Connect your smartphone or tablet directly to your printer - and easily print without accessing a network. Print remotely without worries. The auto-deploying output tray keeps your pages from landing on the floor.
Say hello to productivity
Take charge of your tasks with the easy-to-use 2.2-inch display - simply touch and go. Use the automatic document feeder to quickly tackle multi-page jobs. Automatic two-sided printing saves paper. Print borderless, lab-quality photos and laser-quality documents right in your home.
Perfect for your home and home office
Save your space with a sleek all-in-one designed to fit where you need it. Print in any room you choose without causing disruptions.
HP Officejet 4650 All-in-One - multifunction printer - colour - HP Instant Ink eligible
Multifunction printer
Fax Type
Plain paper
English / Ireland
Printing Technology
Ink-jet (colour)
Inkjet Technology
HP Thermal Inkjet - 4-ink
Monthly Duty Cycle (max)
1200 pages
Recommended Monthly Volume
100 - 400 pages
Max Copying Speed
Up to 7.5 ppm (mono) / up to 4 ppm (colour)
Max Copying Resolution
Up to 600 x 300 dpi (mono) / up to 600 x 300 dpi (colour)
Max Printing Speed
Up to 9.5 ppm (mono) / up to 6.8 ppm (colour)
Max Printing Resolution
Up to 1200 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
300 x 300 dpi, 1200 x 1200 dpi
Scanning
1200 x 1200 dpi
Display
2.2"
Original Size
Letter A (216 x 279 mm)/A4 (210 x 297 mm) (max)
Original Type
Sheets
Document Feeder Capacity
35 sheets
Media Size
76.2 x 127 mm (min) - Legal (216 x 356 mm) (max)
Media Type
Plain paper, photo paper
Standard Media Capacity
100 sheets
Output Trays Capacity
25 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
USB 2.0, Wi-Fi(n)
AirPrint Enabled
Office Machine Features
Scan to e-mail, automatic paper sensor, Mobile Printing
AC 120/230 V (50/60Hz)
44.5 cm x 36.9 cm x 19.1 cm
6.55 kg
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Fax Type
Plain paper
Printing Technology
Ink-jet - colour
1200 pages
100 - 400 pages
Display Diagonal Size
2.2"
USB 2.0, Wi-Fi(n)
AirPrint Enabled
English / Ireland
Standard Memory
64 MB
Max Supported Memory
64 MB
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
50
Printing
Inkjet Technology
HP Thermal Inkjet
Max Printing Speed
Ink Cartridge Configuration
1 black cartridge, 1 colour cartridge (cyan, magenta, yellow)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Printer Drivers / Emulations
PCL 3 GUI
Automatic Duplexing
First Print Out Time B/W
18 sec
Scanning
Scan Element
CIS
Optical Resolution
1200 x 1200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Fax Machine
Max Transmission Speed
33.6 Kbps
Fax Resolutions
Total Memory Capacity
Up to 99 pages
Fax Printing Speed
Up to 20 ppm
Fax Machine Features
Speed Dialing
99 station(s)
Delayed Transmission
Remote Fax Retrieval (Polling)
Fax forwarding
Document & Media Handling
Max Original Size
Original Type
Sheets
35 sheets
Min Media Size
76.2 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
64 g/m²
Max Media Weight
90 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), C6 (114 x 162 mm), 101.6 x 152.4 mm, 76.2 x 127 mm, 127 x 177.8 mm, 215 x 355 mm, 203.2 x 254 mm, DL (210 x 99 mm), 215 x 309 mm, 76.2 x 140 mm
Printing: up to 9.5 ppm - B/W (ISO) , Printing: up to 6.8 ppm - colour (ISO) , Printing: up to 20 ppm - B/W draft , Printing: up to 16 ppm - colour draft , Copying: up to 7.5 ppm - B/W (ISO) , Copying: up to 4 ppm - colour (ISO) , Scanning: up to 8 ppm - B/W , Scanning: up to 4 ppm - colour
1 x USB 2.0 - 4 pin USB Type B , 1 x modem - RJ-11
Operating System Support
MS Windows 7, MS Windows XP SP3, MS Windows Vista, Apple Mac OS X 10.8, Windows 8, Windows 8.1, Apple Mac OS X 10.9, Apple Mac OS X 10.10, Windows 10
Software Included
Drivers & Utilities, HP Photo Creations, HP Update
15 Watt
Power Consumption Standby
3.45 Watt
Power Consumption Sleep
0.65 Watt
Phone cable
Consumables Included
1 x ink cartridge (black) - up to 190 pages - HP 63 , 1 x ink cartridge (yellow/cyan/magenta) - up to 165 pages - HP 63
