Don't wait for documents. Print your first page in as few as 9 seconds from energy-efficient sleep mode.Speed through jobs. Print two sides as quickly – as one – up to 38 ipm – and scan both sides of the page at once.This MFP uses exceptionally low amounts of energy – thanks to its innovative design and toner technology.Choose a maximum capacity of up to 2,300 sheets. Print up to 59 pages per minute on A5.
Unparalleled fleet security and management
Embedded features detect security threats and heal your MFP, protecting it from boot up to shutdown.Protect sensitive data on the MFP and in transit, using embedded security features and 256-bit encryption.Protect sensitive business data with embedded and optional HP JetAdvantage Security Solutions.Centralise control of your printing environment with HP Web Jetadmin – and help build business efficiency.
More
Make an impression with leading colour quality from HP. Get unparalleled printing for your office needs.Get more pages with each Original HP Toner cartridge with JetIntelligence and high-yield cartridges.Help ensure the Original HP quality you paid for with anti-fraud and cartridge authentication technology.Print right away with preinstalled toner cartridges. Replace them with cartridges featuring auto seal removal.
Stay connected with secure mobile printing options
Use optional, 128-bit encrypted wireless direct printing from mobile devices – no network needed.Add the option to print with a touch of your NFC-enabled mobile device to this printer – no network needed.Easily print from a variety of smartphones and tablets – generally no setup or apps required.Easily access, print, and share resources with Ethernet and optional wireless networking.
HP Color LaserJet Enterprise MFP M577f - multifunction printer - colour
Multifunction printer
Fax Type
Plain paper
English, German, French, Italian, Spanish / Europe
Printing Technology
Laser (colour)
Monthly Duty Cycle (max)
80000 pages
Recommended Monthly Volume
2000 - 7500 pages
Max Copying Speed
Up to 38 ppm (mono) / up to 38 ppm (colour)
Max Copying Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed
Max Printing Resolution
Up to 1200 x 1200 dpi (mono) / up to 1200 x 1200 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
300 x 300 dpi, 400 x 400 dpi, 204 x 98 dpi, 204 x 196 dpi
Scanning
600 x 600 dpi
Display
8"
Original Size
Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
100 sheets
Media Size
76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Transparencies, envelopes, plain paper, labels, recycled paper, bond paper, heavy-weight paper, card stock, extra heavy-weight paper, light-weight paper, glossy paper, preprinted paper
Standard Media Capacity
650 sheets
Max Media Capacity
2300 sheets
Bypass Feeder Capacity
100 sheets
Output Trays Capacity
250 sheets
Automatic Duplexing
Yes (copying) Yes (printing)
Connection Availability
USB 2.0, Gigabit LAN, USB 2.0 host
AirPrint Enabled
Office Machine Features
Document send function, save to USB flash drive, scan to e-mail, scan to network, Hardware Integration Pocket, security lock slot
AC 230 V (50Hz)
48.2 cm x 50.4 cm x 58.3 cm
38.3 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Fax Type
Plain paper
Printing Technology
Laser - colour
80000 pages
2000 - 7500 pages
Display Diagonal Size
8"
Display Features
Touch screen
AirPrint Enabled
Standard Memory
1.75 GB
Max Supported Memory
2.5 GB
Hard Disk Drive
320 GB
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
9999
Automatic Duplexing
Copying Features
ID Card Copy
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 6, PostScript 3, PCL 5c, PDF 1.7
Image Enhancement Technology
HP ImageREt 3600
Automatic Duplexing
First Print Out Time B/W
5.6 sec
First Print Out Time Colour
6.9 sec
Scanning
Scan Element
CIS
Optical Resolution
600 x 600 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Fax Machine
Max Transmission Speed
33.6 Kbps
Fax Resolutions
PC Faxing
Fax Machine Features
Fax forwarding, automatic redialing, junk fax barrier, auto reduction
Document & Media Handling
Max Original Size
Original Type
Sheets
100 sheets
Min Media Size
76 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
220 g/m²
Supported Media Type
Supported Media Sizes
Legal (216 x 356 mm), A4 (210 x 297 mm), 76 x 127 mm
650 sheets
Max Media Capacity
2300 sheets
100 sheets
250 sheets
ADF - 100 sheets - Legal (216 x 356 mm) , Input tray - 550 sheets size: 102 x 148 mm - 216 x 297 mm weight: 60 g/m² - 220 g/m² , Bypass tray - 100 sheets size: 76 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , Output tray - 250 sheets
Speed Details
Scanning: up to 43 ppm (A4) - B/W normal , Scanning: up to 43 ipm (A4) - B/W normal , Scanning: up to 38 ppm (A4) - colour normal , Scanning: up to 38 ipm (A4) - colour normal , Printing: up to 38 ppm (A4) - B/W (ISO) , Printing: up to 38 ppm (A4) - colour (ISO) , Printing: up to 40 ppm (Letter A) - B/W (ISO) , Printing: up to 40 ppm (Letter A) - colour (ISO) , Printing: up to 59 ppm (A5) - B/W , Printing: up to 59 ppm (A5) - colour , Printing: up to 38 ppm (A4) - B/W duplex , Printing: up to 38 ppm (A4) - colour duplex , Printing: up to 40 ppm (Letter A) - B/W duplex , Printing: up to 40 ppm (Letter A) - colour duplex , Copying: up to 38 ppm (A4) - B/W (ISO) , Copying: up to 38 ppm (A4) - colour (ISO) , Copying: up to 40 ppm (Letter A) - B/W (ISO) , Copying: up to 40 ppm (Letter A) - colour (ISO) , Copying: up to 38 ppm (A4) - B/W duplex , Copying: up to 38 ppm (A4) - colour duplex , Copying: up to 40 ppm (Letter A) - B/W duplex , Copying: up to 40 ppm (Letter A) - colour duplex
1 x Gigabit LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B , 2 x USB 2.0 host - 4 pin USB Type A , 1 x modem - RJ-11
UNIX, MS Windows XP SP3, MS Windows Vista, Ubuntu Linux 10.04, Ubuntu Linux 11.10, Ubuntu Linux 12.04, Apple Mac OS X 10.8, Fedora 17, Android, iOS, Fedora 18, openSUSE 12.2, openSUSE 12.3, Ubuntu Linux 12.10, Linux Mint 13, Linux Mint 14, Apple Mac OS X 10.9, Windows RT 8.1, Fedora 19, MS Windows 7 (32/64 bits), Ubuntu Linux 13.04, Linux Mint 15, Windows RT 8, Apple Mac OS X 10.10, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), openSUSE 13.1 (32/64-bit), Ubuntu Linux 13.10, Windows 10 (32/64-bits), Boss 3.0, Boss 5.0, Ubuntu Linux 14.10, Debian Linux 7.x, Fedora 20, Linux Mint 16, Linux Mint 17, Ubuntu Linux 14.04, Debian Linux 6.0.x
Software Included
Drivers & Utilities
AC 230 V (50Hz)
592 watt
Power Consumption Standby
47.3 watt
Power Consumption Sleep
3.48 watt
First Copy Out Time B/W
5.6 sec
First Copy Out Time Colour
9.1 sec
Consumables Included
1 x toner cartridge (black) - up to 6000 pages , 1 x toner cartridge (cyan) - up to 5000 pages , 1 x toner cartridge (magenta) - up to 5000 pages , 1 x toner cartridge (yellow) - up to 5000 pages
UL, cUL, GS, IEC 60950-1, EN 60950-1, EN 60825-1, CAN/CSA C22.2 No. 60950-1-07, EN 62479:2010
