Easy to install, this affordable, full-featured MFP prints, copies, scans and faxes. Enable easy printing from smartphones, tablets and laptops – at work, home, or on the go – with wireless connectivity and mobile printing features.
Handle the essentials with one affordable, networked MFP
Easily manage your MFP from the 7.6 cm (3-inch) colour touchscreen. Use the simple, intuitive control panel to set up projects easily and start printing right away.Finish projects fast – print documents at up to 20 ppm and get a first page out in as fast as 9.5 seconds with Instant-On Technology. Use the 35-page automatic document feeder to make the most of your time.Easily copy both sides of a two-sided ID or other small document onto the front of a single-page.Keep up with the pace of business with an MFP that prints, copies, faxes and scans.
Print on your terms: from your smartphone, tablet and PC
Extend your printing reach. Easily set up, print, and share using Ethernet and wireless connectivity.Connect to your wireless printer in a snap using wireless direct printing.Print from your mobile device with built-in print capability or HP ePrint app and software.Print from virtually anywhere with AirPrint .
Get going with no delays: this fast printer offers ease-of-use and energy savings
Spend less time at your MFP and more with your customers. Print, copy, and scan at high speeds that keep up with the pace of business.Help save energy with HP Instant-on Technology and HP Auto-On/Auto-Off Technology.
HP LaserJet Pro MFP M127fn - multifunction printer - B/W
Multifunction printer
Fax Type
Plain paper
English, German, French, Italian, Spanish / Europe
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
8000 pages
Recommended Monthly Volume
250 - 2000 pages
Max Copying Speed
Up to 20 ppm
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 20 ppm
Max Printing Resolution
Up to 600 x 600 dpi
Max Fax Transmission Speed
33.6 Kbps
Scanning
1200 x 1200 dpi
Original Size
Legal (216 x 356 mm) (max)
Document Feeder Capacity
35 sheets
Media Size
76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), JIS B5 (182 x 257 mm)
Supported Envelope Sizes
US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm)
Standard Media Capacity
150 sheets
Output Trays Capacity
100 sheets
ADF - 35 sheets - Legal (216 x 356 mm) , Input tray - 150 sheets size: 76 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m² , Output tray - 100 sheets
Speed Details
Printing: up to 21 ppm (Letter A) - B/W normal , Printing: up to 20 ppm (A4) - B/W normal , Copying: up to 21 ppm (Letter A) - B/W normal , Copying: up to 20 ppm (A4) - B/W normal , Scanning: up to 7 ppm (A4) - B/W normal , Scanning: up to 5 ppm (A4) - colour normal
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
Operating System Support
Linux, MS Windows XP SP2 or later, MS Windows 7, MS Windows Vista, MS Windows Server 2008, Apple Mac OS X 10.6.8 or later, MS Windows Server 2003 SP1 or later, MS Windows Server 2012, Windows 8, MS Windows Server 2008 R2 SP1
Software Included
Drivers & Utilities, HP Toolbox
AC 230 V (50/60Hz)
480 Watt
Power Consumption Standby
4.5 Watt
Power Consumption Sleep
1.1 Watt
First Copy Out Time B/W
15 sec
USB cable, phone cable
Consumables Included
1 x toner cartridge (black) - up to 700 pages
Compatible with Windows 7
UL, cUL, GS, ICES-003, EN55024, CISPR 22, EN55022 Class B, Laser Class 1, IEC 60950-1, FCC CFR47 Part 15 B, EN 60825-1, Directive 2004/108/EC, GB 9254-2008, Directive 2006/95/EC, EN 61000-3-3:2008, GB 17625.1-2003 EMC, EN 61000-3-2:2006+A1:2009+A2:2009, EN 60950-1:2006, IEC 60825-1:2007
