Print, scan and copy with the proven reliability of the cheapest compact laser multifunction printer from HP. Get professional results and the performance you expect.
Outstanding reliable quality without compromise
Easily print high-quality documents and with the reliability you expect from the leader in laser printing. Print directly from the start with a pre-installed cassette and an intuitive LED panel. HP Auto-On / Auto-Off technology helps to save energy.
Maximum productivity for business in compact format
Stay productive. Quickly and easily print, scan and copy documents with an efficient, compact laser multifunction printer designed to fit on small workspaces. This multifunction printer from HP provides high-quality results with HP toner cartridges.
Even results that match your work
Provides consistent results that you can trust. You can easily connect to a PC or laptop with USB and start printing. Together with Original HP print cartridges deliver this multifunction printer from HP performance with high quality.
