This powerful MFP increases productivity with automatic two-sided printing, an intuitive touchscreen with scan-to options, easy wireless connectivity, built-in networking and mobile printing options.
Save time and help reduce paper costs, using reliable automatic two-sided printing.Scan and send digital files directly to a USB drive, the cloud, email or network folders (only available on the HP LaserJet Pro MFP M225dw).Work smarter – access content and quickly launch tasks from the 7.6 cm colour touchscreen.Improve office efficiency with the automatic document feeder and included, 1,500-page toner cartridge.
Connect and protect your MFP
Connect, manage and take full advantage of this MFP's built-in features.Start printing, scanning and copying right away with easy setup.Easily share this MFP using Ethernet connectivity. Choose the M225dw model with built-in wireless connectivity to print from virtually anywhere in the office.Connect via USB and access tools at your PC to manage your MFP and supplies.
Reduce your impact
Help save energy with HP Auto-On/Auto-Off Technology.Print reliably on a wide range of paper types – including office papers as light as 60 g/m2.Count on easy, free cartridge recycling through HP Planet Partners.Conserve resources with an MFP that's ENERGY STAR qualified and Blue Angel compliant.
HP LaserJet Pro MFP M225dw - multifunction printer - B/W
Multifunction printer
Fax Type
Plain paper
English, German, French, Italian, Spanish / Europe
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
8000 pages
Recommended Monthly Volume
500 - 2000 pages
Max Copying Speed
Up to 25 ppm
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 25 ppm
Max Printing Resolution
Up to 1200 x 1200 dpi
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
203 x 98 dpi, 203 x 196 dpi, 300 x 300 dpi
Scanning
1200 x 1200 dpi
Display
3"
Original Size
Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
35 sheets
Media Size
76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), JIS B5 (182 x 257 mm), 76 x 127 mm, 76 x 187 mm
Supported Envelope Sizes
International DL (110 x 220 mm), International C5 (162 x 229 mm)
Standard Media Capacity
250 sheets
Max Media Capacity
250 sheets
Bypass Feeder Capacity
10 sheets
Output Trays Capacity
100 sheets
Input tray - 250 sheets size: 76 x 187 mm - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m² , Output tray - 100 sheets , ADF - 35 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 75 g/m² , Bypass tray - 10 sheets size: 76 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m²
Speed Details
Printing: up to 26 ppm (Letter A) , Copying: up to 26 ppm (Letter A) , Scanning: up to 15 ppm - B/W , Scanning: up to 6 ppm - colour , Copying: up to 26 ppm (Letter A) , Copying: up to 26 ppm (Letter A) , Copying: up to 25 ppm (A4) , Copying: up to 25 ppm (A4) , Printing: up to 25 ppm (A4) , Printing: up to 25 ppm (A4) , Scanning: up to 14 ppm (A4) - B/W normal , Scanning: up to 5 ppm (A4) - colour normal , Printing: up to 15 ipm (A4) - B/W duplex
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45 , 1 x USB host - 4 pin USB Type A , 1 x modem - RJ-11
Operating System Support
MS Windows XP SP2 or later, MS Windows 7, Apple Mac OS X 10.7, MS Windows Server 2008 R2 x64 Edition, MS Windows Server 2003 SP1 or later, Apple Mac OS X 10.8, MS Windows Server 2012, Windows 8, MS Windows Server 2008 R2 SP1, Windows 8.1, Apple Mac OS X 10.9, MS Windows Server 2003 R2 (32/64-bits), MS Windows Server 2008 (32/64-bits), MS Windows Server 2012 R2 x64 Edition, MS Windows Vista (32/64 bits)
Software Included
Drivers & Utilities
AC 230 V (50/60Hz)
470 Watt
Power Consumption Standby
4.5 Watt
USB cable, phone cable, Ethernet cable
Consumables Included
1 x toner cartridge (black) - up to 1500 pages
Compatible with Windows 7
FCC Class B certified, CISPR 22 Class B, GS, ICES-003, EN55022 Class B, EMC, Laser Class 1, FCC CFR47 Part 15, EN 60825-1, GB 9254-2008, EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009, IEC 60825-1:2007, IEC 60950-1:2005, GB 17625.1-2012, EN60950-1:2006 + A11:2009 + A1:2010 + A12:2011, EN 55024:2010
