This black-and-white desktop MFP increases productivity with automatic two-sided printing, built-in networking, security features and mobile printing options.
Save time and help reduce paper costs, using reliable automatic two-sided printing.Just start printing, quick and easy – with the simple control panel.Reduce employee time at the MFP, using the automatic document feeder.Put this MFP to work, right out of the box – full-capacity, 1,500-page toner cartridge included.
Connect and protect your MFP
Easily manage settings and help keep data secure with built-in features.Easily share this MFP using Ethernet connectivity.Connect via USB and access tools at your PC to manage your MFP and supplies.
Reduce your impact
Help save energy with HP Auto-On/Auto-Off Technology.Print reliably on a wide range of paper types – including office papers as light as 60 g/m2.Count on easy, free cartridge recycling through HP Planet Partners.Conserve resources with an MFP that's ENERGY STAR qualified and Blue Angel compliant.
HP LaserJet Pro MFP M225dn - multifunction printer - B/W
Multifunction printer
Fax Type
Plain paper
English, German, French, Italian, Spanish / Europe
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
8000 pages
Recommended Monthly Volume
500 - 2000 pages
Max Copying Speed
Up to 25 ppm
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 25 ppm
Max Printing Resolution
Up to 600 x 600 dpi
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
203 x 98 dpi, 203 x 196 dpi, 300 x 300 dpi
Scanning
1200 x 1200 dpi
Original Size
Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
35 sheets
Media Size
76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), JIS B5 (182 x 257 mm), 76 x 127 mm, 76 x 187 mm
Supported Envelope Sizes
International DL (110 x 220 mm), International C5 (162 x 229 mm)
Standard Media Capacity
250 sheets
Max Media Capacity
250 sheets
Bypass Feeder Capacity
10 sheets
Output Trays Capacity
100 sheets
Input tray - 250 sheets size: 76 x 187 mm - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m² , Output tray - 100 sheets , ADF - 35 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 75 g/m² , Bypass tray - 10 sheets size: 76 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m²
Speed Details
Printing: up to 26 ppm (Letter A) , Copying: up to 26 ppm (Letter A) , Scanning: up to 15 ppm - B/W , Scanning: up to 6 ppm - colour , Copying: up to 26 ppm (Letter A) , Copying: up to 26 ppm (Letter A) , Copying: up to 25 ppm (A4) , Copying: up to 25 ppm (A4) , Printing: up to 25 ppm (A4) , Printing: up to 25 ppm (A4) , Scanning: up to 14 ppm (A4) - B/W normal , Scanning: up to 5 ppm (A4) - colour normal , Printing: up to 15 ipm (A4) - B/W duplex
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45 , 1 x USB host - 4 pin USB Type A , 1 x modem - RJ-11
Operating System Support
MS Windows XP SP2 or later, MS Windows 7, Apple Mac OS X 10.7, MS Windows Server 2008 R2 x64 Edition, MS Windows Server 2003 SP1 or later, Apple Mac OS X 10.8, MS Windows Server 2012, Windows 8, MS Windows Server 2008 R2 SP1, Windows 8.1, Apple Mac OS X 10.9, MS Windows Server 2003 R2 (32/64-bits), MS Windows Server 2008 (32/64-bits), MS Windows Server 2012 R2 x64 Edition, MS Windows Vista (32/64 bits)
Software Included
Drivers & Utilities
AC 230 V (50/60Hz)
470 Watt
Power Consumption Standby
4.5 Watt
USB cable, phone cable, Ethernet cable
Consumables Included
1 x toner cartridge (black) - up to 1500 pages
FCC Class B certified, CISPR 22 Class B, GS, ICES-003, EN55022 Class B, EMC, Laser Class 1, FCC CFR47 Part 15, EN 60825-1, GB 9254-2008, EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009, IEC 60825-1:2007, IEC 60950-1:2005, GB 17625.1-2012, EN60950-1:2006 + A11:2009 + A1:2010 + A12:2011, EN 55024:2010
