Enhance security with plenty of built-in and optional security features, increase productivity with fast print speeds and print from smartphones, tablets or laptops with mobile printing options.
Easily manage settings and help keep data secure with built-in features.Easily share this printer using Ethernet connectivity.Connect via USB and access tools from your PC to manage your printer and supplies.
Just print – protected and connected
Speed through printing tasks using the simple control panel.Work with less wait. Step up your productivity with fast print speeds of up to 26 pages per minute.Start working, right out of the box – full-capacity, 1,500-page toner cartridge included.Print projects without pause – this printer has a 250-sheet input tray plus a 10-sheet priority feed slot.
Reduce your impact
Help save energy with HP Auto-On/Auto-Off Technology.Print reliably on a wide range of paper types – including office papers as light as 60 GSM.Count on easy, free cartridge recycling through HP Planet Partners.Conserve resources with a printer that's ENERGY STAR qualified and Blue Angel compliant.
HP LaserJet Pro M201n - printer - B/W - laser
Printer Type
Workgroup printer - laser - B/W
5.9 kg
English, German, French, Italian, Spanish / Europe
Microsoft Windows 7 64-bit Edition, Microsoft Windows Vista (32-bit versions), Microsoft Windows Server 2003 SP1 or later, Microsoft Windows Vista (64-bit versions), Microsoft Windows Server 2003 R2, Microsoft Windows Server 2008 x64 Edition, Microsoft Windows Server 2008 R2 x64 Edition, Apple MacOS X Lion 10.7, Apple OS X 10.8 Mountain Lion, Windows 8 64-bit Edition, Windows 8 32-bit Edition, Microsoft Windows Server 2008 32-bit, Microsoft Windows Server 2012 x64 Edition, Windows 8.1 32-bit Edition, Windows 8.1 64-bit Edition, Apple OS X 10.9 Mavericks, Microsoft Windows Server 2012 R2 x64 Edition, Microsoft Windows Server 2008 R2 SP1 (64-bits), Microsoft Windows 7 32-bit Edition
1-year warranty
37.9 cm x 24.19 cm x 25.14 cm
Printer Type
Workgroup printer - laser - monochrome
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 76 x 127 mm, 147 x 211 mm, 76 x 187 mm
Envelope Sizes
US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm)
Media Weight
60 g/m² - 163 g/m²
Total Media Capacity
260 sheets
Media Feeders
1 x automatic - 10 sheets - Legal (216 x 356 mm) , 1 x automatic - 250 sheets - Legal (216 x 356 mm)
Output Trays Capacity
150 sheets
Duty Cycle
Monthly Duty Cycle (max)
8000 pages
Recommended Monthly Volume
250 - 2000 pages
Print server
Remote Management Protocol
SNMP 1
1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45
Consumables Included
1 x toner cartridge (black) - up to 1500 pages
FCC Class B certified, CISPR 22 Class B, ICES-003, EN55022 Class B, EMC, Laser Class 1, FCC CFR47 Part 15, EN 60825-1, LVD, GB 9254-2008, EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009, IEC 60825-1:2007, IEC 60950-1:2005, GB 17625.1-2012, EN60950-1:2006 + A11:2009 + A1:2010 + A12:2011, EN 55024:2010
Power supply - internal
Frequency Required
50 Hz
450 Watt
Power Consumption Stand by
2.2 Watt
Software Included
Drivers & Utilities
System Requirements Details
Windows Vista/7/8/8.1/2008 (64 bits) - 1 GHz - RAM 2 GB - HD 400 MB , Windows Vista/7/8/8.1/2008 (32 bits) - 1 GHz - RAM 1 GB - HD 400 MB , Windows Server 2003 - 1 GHz - RAM 1 GB - HD 400 MB , MacOS X 10.7/10.8/10.9 - HD 1 GB
