Tackle daily business tasks with a cost-effective, fast HP LaserJet MFP. Print two-sided documents from anywhere, using HP ePrint. Streamline your workflow by copying, scanning, faxing and connecting securely via Ethernet networking.
Do more with a fast, networked MFP and two-sided printing
Stay productive: print at up to 25 ppm A4 and get a first page out in as fast as 8.5 seconds with Instant-on Technology.Share printing resources on a network with built-in 10/100 Ethernet connectivity.Use the 35-page automatic document feeder to print two-sided pages, or to copy and fax multiple-page documents.Save paper and time: fax documents directly to and from a PC and desktop applications, and control access to the faxing features with assigned PINs.
Create a variety of high-quality business documents in multiple sizes
Print professional documents with bold text and sharp images, using Original HP LaserJet print cartridges for consistently excellent quality every time you print.Achieve improved print quality with HP FastRes 1200: bring your documents to life with fine details, solid fills and smooth transitions.Add variety to your documents: the 10-sheet priority tray and 250-sheet paper tray enable you to use a variety of media sizes and types.
Print from anywhere and use intuitive features
Print from anywhere, anytime, with a smartphone, notebook PC or other mobile device, using HP ePrint and print wirelessly from your iPad , iPhone and iPod touch with AirPrint .Simplify printing tasks with an intuitive and easy to navigate control panel and LCD. Use ID Copy to create a one-sided copy of a two-sided ID.Easily find and purchase cartridge replacements with HP SureSupply and install them without hassle.Use embedded HP tools for easy MFP configuration, operation and maintenance.
Minimise your environmental impact
Reduce your impact on the environment, and use up to 50% less paper with two-sided printing.Conserve energy with Instant-on Technology and Instant-on Copy.Get free and easy recycling – cartridges returned through HP Planet Partners are recycled responsibly.Save energy and space with a compact, ENERGY STAR qualified MFP.
HP LaserJet Pro M1536dnf - multifunction printer - B/W
MS Windows XP, Linux, MS Windows Server 2003, MS Windows 7, Apple Mac OS X 10.6.x, Apple Mac OS X 10.5.8, MS Windows Vista
445 watt
Power Consumption Standby
4.7 watt
Compatible with Windows 7
