| Quicklinx: | 98T0WS00 |
| Mfr#: | CZ183A#B19 |
Easy to install, this affordable, full-featured MFP prints, copies, scans and faxes. Enable easy printing from smartphones, tablets and laptops – at work, home, or on the go – with wireless connectivity and mobile printing features.
Get it all done – with a wireless MFP that’s easy on your budget. Use the 3-inch colour touchscreen and simply tap to print, copy, scan and fax professional-quality documents.
Easily manage your MFP from the 7.6 cm (3-inch) colour touchscreen. Use the simple, intuitive control panel to set up projects easily and start printing right away. Finish projects fast – print documents at up to 20 ppm and get a first page out in as fast as 9.5 seconds with Instant-On Technology. Use the 35-page automatic document feeder to make the most of your time. Easily copy both sides of a two-sided ID or other small document onto the front of a single-page. Keep up with the pace of business with an MFP that prints, copies, faxes and scans.
Get right to printing, right away.
Spend less time at your MFP and more with your customers. Print, copy, and scan at high speeds that keep up with the pace of business. Help save energy with HP Instant-on Technology and HP Auto-On/Auto-Off Technology.
Enable easy printing from smartphones, tablets and laptops, at work, home or on the go.
Extend your printing reach. Easily set up, print, and share using Ethernet and wireless connectivity. Connect to your wireless printer in a snap using wireless direct printing. Print from your mobile device with built-in print capability or HP ePrint app and software. Print from virtually anywhere with AirPrint™.
