Tackle everyday office tasks with an affordable, full-featured MFP. Plug and print with HP Smart Install. Easily print, copy, scan and fax from one compact machine. Share resources with Ethernet networking or work anywhere with wireless.
Be more efficient with this affordable, full-featured MFP
Share on a network and work from anywhere in the office, using built-in Ethernet and wireless connectivity.Create professional-quality documents with bold, crisp text and sharp images, using HP Original print cartridges.Send and receive faxes from your PC, using the 33.6 kbps fax.Print documents at up to 18 ppm A4. With Instant-on Technology, pages start and finish printing quickly: get a first page out in as fast as 8.5 seconds.
Get up and running quickly and easily
Plug and print in as fast as five minutes: HP Smart Install makes it easy to start printing from a PC or Netbook – no CD required.Set up and start printing fast with an easy-to-use, intuitive control panel. Easily make a one-sided copy of a two-sided identification card with ID Copy.Connect the MFP directly to a PC or Netbook via the included Hi-speed USB 2.0 port.Ensure reliable printing with an HP all-in-one print cartridge. Easily replace it with HP SureSupply.
Reduce your environmental impact and protect your bottom line
Get up to 50% energy savings using Instant-on Technology and save up to four times the energy with Instant-on Copy. Save even more with HP Auto-On/Auto-Off Technology which senses your printing activity, turning on and off automatically.Reduce waste: a pre-installed cartridge decreases packaging. Recycle easily with HP Planet Partners.Get more value and better results with the services, solutions, software and support of HP Total Care.Save energy with an ENERGY STAR qualified MFP.
HP LaserJet Pro M1217nfw MFP - multifunction printer - B/W
Multifunction printer
Copier Type
Digital
Fax Type
Plain paper
English, German, French, Italian, Spanish / Europe
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
8000 impressions
Recommended Monthly Volume
250 - 2000 pages
Max Copying Speed
Up to 18 ppm
Max Copying Resolution
Up to 600 x 400 dpi
Max Printing Speed
Up to 18 ppm
Max Printing Resolution
Up to 1200 dpi
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
203 x 98 dpi, 300 x 300 dpi
Scanning
1200 x 1200 dpi
Original Size
Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
35 sheets
Media Size
76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Printing: up to 18 ppm (A4) - B/W , Copying: up to 18 ppm (A4) - B/W
1 x USB 2.0 , 1 x LAN
Operating System Support
MS Windows XP, Linux, MS Windows Server 2003, Apple Mac OS X 10.4, Apple Mac OS X 10.5, MS Windows 7, MS Windows Vista, MS Windows Server 2008, Apple Mac OS X 10.6
Software Included
Readiris Pro
AC 230 V (50/60Hz)
370 Watt
Power Consumption Standby
4.8 Watt
Power Consumption Sleep
2 Watt
USB cable, phone cable
Consumables Included
1 x toner cartridge (black)
EN 61000-3-2, EN55022, IEC 61000-4-11, EN 61000-3-3, EN55024, CISPR 22, RSS-210, EN 61000-4-4, EN 61000-4-3, EN 61000-4-6, FCC Part 68, EN 61000-4-5, UL 60950-1, IEC 60950-1, EN 60950-1, EN 300.489.1, IEC 60825-1, FCC CFR47 Part 15 C, TBR21, EN 60825-1, EN 300 328
