Enhance productivity and get great value for money with this black-and-white HP LaserJet
Enjoy fast print speeds of up to 30 ppm and get a fast first page out from low power mode with Instant-on Technology.Conveniently connect your printer to a computer using the USB or parallel port.Print a variety of office documents of almost any length, with a 250-sheet input tray; the 50-sheet multipurpose tray supports a variety of print media.Process complex files quickly with a 266 MHz processor and 16 MB memory.
Achieve impressive, professional quality results with this conveniently compact printer
Print professional-quality documents with crisp text and sharp images thanks to HP FastRes 1200 which provides 1200 dpi effective output quality.This sleek, space-saving printer's compact design ensures that it fits conveniently into a small area of the desktop.Reduce operation noise with the printer's unique Quiet mode.The reliable all-in-one HP LaserJet print cartridge is designed to meet your usage needs, optimise print quality and provide excellent value.
Extremely easy to set up, use, and maintain
Interactive intelligence built into the Original HP print cartridge optimises print quality and provides alerts when supplies are low, making management straightforward.One-door access to the easy-to-install HP LaserJet Print Cartridge means installation and replacement are simple and convenient.Easily navigate printer functions with the simple LED control panel.
You'll hardly notice it's there
Select quiet mode to reduce printer operation noise.Easily print a range of media sizes including cards and prescription-size forms.
HP LaserJet P2035 - printer - monochrome - laser
Printer Type
Workgroup printer - laser - monochrome
9.9 kg
English / United Kingdom
Max Media Size (Standard)
Legal
Print Speed
Up to 30 ppm - B/W - ANSI A (Letter) (216 x 279 mm)
UNIX, Novell NetWare, Microsoft Windows 2000, Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Microsoft Windows Server 2003, Microsoft Windows XP Professional x64 Edition, Apple MacOS X 10.3.9, Apple MacOS X 10.4.3, Microsoft Windows Vista, Apple MacOS X 10.5.x
Microsoft Certification
Certified for Windows Vista
1 year warranty
36.6 cm x 36.8 cm x 25.7 cm
Printer Type
Printer
Print Speed
A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), C5 (162 x 229 mm)
Total Media Capacity
300 sheets
Media Feeder(s)
1 x autoload - 50 sheets - Legal (216 x 356 mm) , 1 x autoload - 250 sheets - Legal (216 x 356 mm)
Output Trays Capacity
150 sheets
Duty Cycle
Monthly Duty Cycle (max)
25000 pages
1 x USB 2.0 , 1 x parallel
Consumables Included
1 x toner cartridge ( black )
Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
FCC Class B certified, UL, cUL, EN 61000-3-2, GS, ICES-003, IEC 825-1/EN 60825-1 class 1, EN 61000-3-3, EN55024, CISPR 22, EN55022 Class B, EMC, FCC CFR47 Part 15, IEC 60950-1, EN 60950-1
Power supply - internal
AC 220 to 240 V
Frequency Required
50 Hz
550 Watt
Power Consumption Stand by / Sleep
7 Watt
Software Included
Drivers & Utilities
1 year warranty
Service & Support Details
Limited warranty - 1 year - on-site - response time: next business day
