Fulfill workteam A3 printing and copying needs and provide send-to-e-mail from your MFP plus optional fax functionality, with a powerful tool that is affordable and easy to use and makes processes simple and efficient.
This MFP is extremely easy to use, install, manage and maintain with a new, intuitive control panel
Extremely simple to use, manage and maintain, this MFP's new, intuitive user interface is easy to navigate. It comes with an internal hard drive, in-built networking for reliable sharing, and original HP printing supplies that minimise interruptions.
Enhance workteam performance with the A3 multifunction capabilities of this robust, affordable MFP
Easily add A3 multifunction capabilities to your office without stretching your budget. Accomplish more with A3 printing and copying at speeds of up to 35 ppm, optional fax and embedded send-to-e-mail functionality directly from your MFP.
Experience familiar HP LaserJet reliability and quality for results you can always depend on
Get results you can count on with HP LaserJet quality and reliability. Create professional documents with flexible paper input. Enjoy worry-free operation with a 400 MHz processor capable of handling complex print jobs, and expandable memory.
HP LaserJet M5035x MFP - multifunction printer - B/W
Multifunction printer
Copier Type
Digital
Fax Type
Super G3 - plain paper
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
200000 impressions
Max Copying Speed
Up to 35 ppm
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 35 ppm
Max Printing Resolution
Up to 1200 x 1200 dpi
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
300 x 300 dpi, 200 x 200 dpi
Scanning
600 x 600 dpi
Original Size
76 x 127 mm (min) - A3/Ledger (297 x 432 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
312 x 470 mm (max)
Media Type
Transparencies, envelopes, plain paper, cards, labels, recycled paper
Standard Media Capacity
1100 sheets
Max Media Capacity
2100 sheets
Bypass Feeder Capacity
100 sheets
Output Trays Capacity
250 sheets
Automatic Duplexing
Yes (copying)
Connection Availability
USB 2.0, LAN
AC 110/230 V (50/60Hz)
74.3 cm x 74.3 cm x 99.7 cm
93 kg
Microsoft Certification
Works with Windows Vista
Environmental Standards
ENERGY STAR Qualified
Copier Type
Digital
Fax Type
Plain paper
Printing Technology
Laser - monochrome
200000 impressions
USB 2.0, LAN
Standard Memory
256 MB 256 MB
Max Supported Memory
512 MB 512 MB
Hard Disk Drive
40 GB
Copying
Max Copying Speed
Up to 35 ppm
Up to 600 x 600 dpi
Grayscale Half-Tones
256
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
1000
Automatic Duplexing
Printing
Max Printing Speed
Up to 35 ppm
Printer Drivers / Emulations
PCL 5e, PCL 6, PostScript 3, PDF 1.4
Image Enhancement Technology
HP FastRes 1200, HP ProRes 1200
First Print Out Time B/W
10 sec
Scanning
Optical Resolution
600 x 600 dpi
Interpolated Resolution
1200 dpi
Grayscale Depth
8-bit
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Fax Resolutions
Fax Printing Resolution
300 x 300 dpi
PC Faxing
Fax Machine Features
Speed Dialing
100 station(s)
Broadcast Transmission
100 stations
Fax forwarding, automatic redialing
Document & Media Handling
Min Original Size
76 x 127 mm
Max Original Size
Original Type
Sheets
50 sheets
Max Media Size
A3
Min Media Weight
60 g/m²
Max Media Weight
105 g/m²
Supported Media Type
1100 sheets
Max Media Capacity
2100 sheets
100 sheets
250 sheets
Bypass tray - 100 sheets size: 76 x 127 mm - 312 x 470 mm weight: 60 g/m² - 120 g/m² , Input tray - 250 sheets size: 148 x 210 mm - 297 x 364 mm weight: 60 g/m² - 120 g/m² , Input tray - 250 sheets size: 148 x 210 mm - A3/Ledger (297 x 432 mm) weight: 60 g/m² - 120 g/m² , Input tray - 500 sheets size: 148 x 210 mm - A3/Ledger (297 x 432 mm) weight: 60 g/m² - 120 g/m² , ADF - 50 sheets size: 138 x 210 mm - A3/Ledger (297 x 432 mm) weight: 60 g/m² - 105 g/m² , Output tray - 250 sheets size: 76 x 127 mm - 312 x 470 mm weight: 60 g/m² - 120 g/m²
Speed Details
Printing: up to 35 ppm - B/W , Copying: up to 35 ppm - B/W
1 x USB 2.0 , 1 x LAN
Network Protocols
IPX/SPX, AppleTalk, DLC/LLC
Operating System Support
MS Windows XP, MS Windows 2000, MS Windows Server 2003, Apple MacOS X 10.2 or later, MS Windows XP Professional x64 Edition, Apple Mac OS X 10.3.9, Apple MacOS X 10.4 or later
Software Included
Drivers & Utilities
1265 Watt
Power Consumption Standby
24 Watt
Power Consumption Sleep
0.1 Watt
Consumables Included
1 x toner cartridge (black) - up to 15000 pages
Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running.
FCC Class B certified, cUL, EN 61000-3-2, ICES-003, NOM, EN 61000-3-3, EN55024, EN55022 Class A, CISPR 22, FCC Part 68, FCC CFR47 Part 15, UL 60950-1, CSA C22.2 No. 60950-1-03
