Accelerate processes and turn documents into dynamic digital files, using a desktop MFP that produces standout colour. Versatile scanning, processing, routing, and retrieval tools help boost productivity. Simplify management and strengthen security.
English, German, French, Italian, Spanish / Europe
Printing Technology
Laser (colour)
Monthly Duty Cycle (max)
75000 impressions
Recommended Monthly Volume
2000 - 6000 pages
Max Copying Speed
Up to 30 ppm (mono) / up to 30 ppm (colour)
Max Copying Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed
Max Printing Resolution
Up to 1200 x 1200 dpi (mono) / up to 1200 x 1200 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
300 x 300 dpi, 204 x 98 dpi, 204 x 196 dpi
Scanning
600 x 600 dpi
Display
8"
Original Size
Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Transparencies, envelopes, plain paper, cards, labels, recycled paper, bond paper, film, heavy-weight paper
Standard Media Capacity
350 sheets
Max Media Capacity
850 sheets
Bypass Feeder Capacity
100 sheets
Output Trays Capacity
250 sheets
Collator
Included
Stapler
Included
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, Gigabit LAN, USB host
AirPrint Enabled
Office Machine Features
Document send function, print from USB flash drive, save to USB flash drive, scan to e-mail, scan to network, Hardware Integration Pocket, HP EveryPage, pull-out keyboard
AC 230 V (50Hz)
66.3 cm x 55.5 cm x 58.5 cm
47.7 kg
Environmental Standards
EPEAT Silver, ENERGY STAR Qualified
Multifunction printer
Copier Type
Digital
Fax Type
Plain paper
Printing Technology
Laser - colour
75000 impressions
2000 - 6000 pages
Display Diagonal Size
8"
Display Features
Touch screen
AirPrint Enabled
Standard Memory
1536 MB 1.5 GB
Max Supported Memory
1536 MB 1.5 GB
Supported Flash Memory
USB flash drive
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
9999
Automatic Duplexing
Copying Features
Auto colour select
Printing
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), JIS B5 (182 x 257 mm), 101.6 x 152.4 mm, Statement (139.7 x 215.9 mm), 76 x 127 mm, 127 x 177.8 mm, Oficio (216 x 343 mm), 127 x 203.2 mm
Supported Envelope Sizes
US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm), US No 9 (98.6 x 225.6 mm)
350 sheets
Max Media Capacity
850 sheets
100 sheets
250 sheets
ADF - 50 sheets - Legal (216 x 356 mm) , Input tray - 250 sheets size: A5 (148 x 210 mm) - Letter A (216 x 279 mm) weight: 60 g/m² - 220 g/m² , Input tray - 100 sheets size: 76 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , Output tray - 250 sheets
Speed Details
Printing: up to 30 ppm (A4) - B/W normal , Copying: up to 30 ppm (A4) - B/W normal , Printing: up to 30 ppm (A4) - colour normal , Copying: up to 30 ppm (A4) - colour normal , Scanning: up to 30 ppm - B/W , Scanning: up to 30 ppm - colour
Finishing Equipment
Collator
Included
Stapler
Included
1 x USB 2.0 , 2 x USB host , 1 x Gigabit LAN
Security Protocols & Features
SSL, TLS, IPsec, 802.1x
Operating System Support
MS Windows Server 2008 x64 Edition, MS Windows XP SP2 or later, Apple Mac OS X 10.5, MS Windows 7, MS Windows Server 2008, Apple Mac OS X 10.6, MS Windows Server 2008 R2, Apple Mac OS X 10.7, MS Windows Server 2008 R2 x64 Edition, MS Windows Server 2003 SP1 or later
Software Included
HP Web Jetadmin
AC 230 V (50Hz)
665 Watt
Power Consumption Standby
52 Watt
Power Consumption Sleep
11.3 Watt
Phone cable
Consumables Included
1 x toner cartridge (black) - up to 5500 pages , 1 x toner cartridge (cyan) - up to 6000 pages , 1 x toner cartridge (magenta) - up to 6000 pages , 1 x toner cartridge (yellow) - up to 6000 pages
FCC Class A certified, UL, CISPR 22 Class A, cUL, EN 61000-3-2, GS, ICES-003, EN 61000-3-3, EN55024, EN55022 Class A, EMC, FCC CFR47 Part 15, IEC 60950-1, EN 60950-1, IEC 60825-1, EN 60825-1, GB 17625.1, LVD, GB 9254-2008
