Increase productivity with this MFP's fast print and copy speeds, an HP Easy Select control panel and outstanding paper-handling features. Use market-leading management tools to integrate the MFP into existing printing environments.
Enjoy productive, dependable performance with this versatile MFP
Stay productive with high performance speeds: print and copy at up to 52 ppm A4.Boost productivity – get up to 2,100-sheet paper capacity for large printing jobs from this workhorse MFP. Save time with a 3-bin, 900-sheet stapling mailbox that sorts, staples and stacks.Preview jobs using the pivoting colour control panel and use image preview to make adjustments to scan jobs.Save time with easy installation, and get exceptional value from optional high-capacity black print cartridges.
Invest in an MFP that integrates easily into IT-managed print environments
Save time and money by proactively managing printing environments, and get easy setup and configuration with HP management tools like industry-leading HP Web Jetadmin.Extend the capabilities of workgroup print environments via the hardware integration pocket with a rich portfolio of easy-to-integrate solutions.Easily update, manage and expand the capabilities of networked printers with HP FutureSmart Firmware.Make printing as mobile as you are with HP ePrint.
Stay in control of sensitive information with advanced security features
Protect sensitive data stored on the HP MFP with the standard encrypted HP High-Performance Secure Hard Disk.Process jobs securely: require a PIN to retrieve print jobs, expand IP addresses on your network with IPv6 and implement network access control with IPSec.Create, print, scan and share sensitive business information securely via encrypted email and PDFs.Add optional authentication security solutions through the hardware integration pocket.
Conserve resources and meet environmental goals with this ENERGY STAR qualified MFP
Reduce energy use with Instant-on Technology and Instant-on Copy.Conserve resources and save paper –automatic two-sided printing reduces paper consumption and PIN printing ensures only authorised use of the MFP.Original HP LaserJet print cartridges with energy-efficient toner enable an energy saving of over 18% on every page you print.Get free, easy cartridge recycling with HP Planet Partners, plus reduce shipping materials with HP ClearView packaging.
HP LaserJet Enterprise M4555h MFP - multifunction printer - B/W
Multifunction printer
Copier Type
Digital
English, German, French, Italian, Spanish / Europe
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
250000 impressions
Recommended Monthly Volume
5000 - 20000 pages
Max Copying Speed
Up to 52 ppm
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 52 ppm
Max Printing Resolution
Up to 1200 x 1200 dpi
Scanning
600 dpi
Display
8.07"
Original Size
Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
A4 (210 x 297 mm) (max)
Media Type
Transparencies, envelopes, plain paper, cards, labels, recycled paper, bond paper
Standard Media Capacity
600 sheets
Max Media Capacity
2100 sheets
Automatic Duplexing
Yes (copying) Yes (printing)
Connection Availability
USB 2.0, Gigabit LAN, USB host
Office Machine Features
Save to USB flash drive, scan to e-mail, scan to network
AC 230 V (50Hz)
79 cm x 51 cm x 57 cm
52.5 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
Copier Type
Digital
Printing Technology
Laser - monochrome
250000 impressions
5000 - 20000 pages
Display Diagonal Size
8.07"
Display Features
Touch screen
Standard Memory
1280 MB 1.25 GB
Max Supported Memory
1280 MB 1.25 GB
Copying
Max Copying Speed
Up to 52 ppm
Up to 600 x 600 dpi
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
9999
Automatic Duplexing
Printing
Max Printing Speed
Up to 52 ppm
Printer Drivers / Emulations
PCL 6, PostScript 3, PCL 5c, PDF 1.4
Image Enhancement Technology
HP FastRes 1200
Automatic Duplexing
First Print Out Time B/W
9.5 sec
Scanning
Optical Resolution
600 dpi
Colour Depth
30-bit
Document & Media Handling
Max Original Size
Original Type
Sheets
50 sheets
Max Media Size
A4
Min Media Weight
60 g/m²
Max Media Weight
200 g/m²
Supported Media Type
Supported Media Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), C5 (162 x 229 mm), JIS B5 (182 x 257 mm), C6 (114 x 162 mm)
Printing: up to 52 ppm (A4) - B/W , Copying: up to 52 ppm (A4) - B/W
1 x USB 2.0 , 1 x USB host , 1 x Gigabit LAN
Network Protocols
IPP
Security Protocols & Features
Kerberos, SSL, TLS, IPsec
Operating System Support
MS Windows Server 2003, MS Windows XP SP2 or later, MS Windows 7, MS Windows Vista, MS Windows Server 2008, MS Windows Server 2008 R2, Apple Mac OS X 10.5 or later
Software Included
Drivers & Utilities
AC 230 V (50Hz)
1024 Watt
Power Consumption Standby
54 Watt
Power Consumption Sleep
21.6 Watt
Phone cable
Consumables Included
1 x toner cartridge (black)
EN 61000-3-2, GS, ICES-003, EN 61000-3-3, EN55024, EN55022 Class A, CISPR 22, EMC, IEC 60950-1, EN 60950-1, FCC CFR47, IEC 60825-1, EN 60825-1
