Print lab-quality photos and laser-sharp documents with this stylish and affordable wireless e-all-in-one. Print from virtually anywhere from your smartphone, tablet or internet-connected PC, and enjoy easy copying and scanning too.
Express your creativity with lab-quality photo printing
Create borderless, lab-quality photos in rich colour and print crisp, laser-sharp documents too.Do even more with easy colour copying and scanning – share photos, capture documents.Save time and paper with automatic two-sided printing and copying.Print and copy more for less with optional high-capacity XL ink cartridges.
Get easy wireless printing from your smartphone or tablet
Enjoy easy wireless printing from virtually anywhere via your smartphone, tablet or internet-connected PC.Scan photos, documents and more directly to your mobile device with HP Printer Control.Use your Apple iPhone or iPad to control print, scan and copy features.Enjoy quick, hassle-free connection to your wireless network with HP Auto Wireless Connect.
Do even more with this versatile and easy-to-use e-all-in-one
View, select and print photos directly via the colour touchscreen and card slots.Spend more time creating and less time waiting with fast print speeds.Compact form and sleek, stylish design – looks great in any room.
HP ENVY 5530 e-All-in-One - multifunction printer - colour
Multifunction printer
Western Europe, United Kingdom, Ireland, Nordics, Baltic Region
Printing Technology
Ink-jet (colour)
Inkjet Technology
HP Thermal Inkjet - 4-ink
Monthly Duty Cycle (max)
1000 impressions
Recommended Monthly Volume
300 - 400 pages
Max Copying Speed
Up to 21 ppm (mono) / up to 17 ppm (colour)
Max Copying Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 1200 dpi (colour)
Max Printing Speed
Up to 8.8 ppm (mono) / up to 5.2 ppm (colour)
Max Printing Resolution
Up to 1200 x 600 dpi (mono) / up to 4800 x 1200 dpi (colour)
Scanning
1200 x 2400 dpi
Display
2.65"
Original Size
216 x 297 mm (max)
Original Type
Sheets
Media Size
76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Transparencies, envelopes, plain paper, cards, labels, iron-on transfers, photo paper
Standard Media Capacity
100 sheets
Max Media Capacity
100 sheets
Output Trays Capacity
30 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
USB 2.0, Wi-Fi(n)
AirPrint Enabled
Office Machine Features
Print from memory card, scan to e-mail, HP Auto Wireless Connect
AC 120/230 V (50/60Hz)
44.5 cm x 33.4 cm x 12 cm
5.56 kg
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Printing Technology
Ink-jet - colour
1000 impressions
300 - 400 pages
Display Diagonal Size
2.65"
Display Features
Touch screen
USB 2.0, Wi-Fi(n)
AirPrint Enabled
Standard Memory
128 MB
Max Supported Memory
128 MB
Supported Flash Memory
SD Memory Card
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
50
Copying Features
ID Card Copy
Printing
Inkjet Technology
HP Thermal Inkjet
Max Printing Speed
Ink Cartridge Configuration
1 black cartridge, 1 colour cartridge (cyan, magenta, yellow)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, pigment black
4-ink
Printer Drivers / Emulations
PCL 3 GUI
Automatic Duplexing
First Print Out Time B/W
19 sec
First Print Out Time Colour
24 sec
Scanning
Scan Element
CIS
Optical Resolution
1200 x 2400 dpi
Interpolated Resolution
2400 x 2400 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Document & Media Handling
Max Original Size
216 x 297 mm
Original Type
Sheets
Min Media Size
76 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
75 g/m²
Max Media Weight
250 g/m²
Supported Media Type
Supported Media Sizes
Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 76 x 127 mm
Supported Envelope Sizes
International DL (110 x 220 mm), International C6 (114 x 162 mm)
Borderless Photo Sizes
216 x 297 mm
100 sheets
Max Media Capacity
100 sheets
30 sheets
Input tray - 100 sheets size: 76 x 127 mm - Legal (216 x 356 mm) weight: 75 g/m² - 250 g/m² , Output tray - 30 sheets
Speed Details
Printing: up to 8.8 ppm - B/W (ISO) , Printing: up to 5.2 ppm - colour (ISO) , Copying: up to 6 ppm (A4) - B/W normal , Copying: up to 4 ppm (A4) - colour normal , Printing: 57 sec (10 x 15 cm (4"x6")) - photo normal , Printing: up to 21 ppm (A4) - B/W draft , Printing: up to 17 ppm (A4) - colour draft , Copying: up to 21 ppm (A4) - B/W draft , Copying: up to 17 ppm (A4) - colour draft , Copying: up to 21 ppm (Letter A) - B/W draft , Copying: up to 17 ppm (Letter A) - colour draft
1 x USB 2.0 - 4 pin USB Type B
Operating System Support
MS Windows 7, MS Windows XP SP3, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows Vista (64-bit versions), Apple Mac OS X 10.6, Apple Mac OS X 10.7, Apple Mac OS X 10.8, Windows 8, Windows 8 64-bit
Software Included
Drivers & Utilities
13.07 Watt
Power Consumption Standby
2.51 Watt
Power Consumption Sleep
0.7 Watt
FCC Class B certified, CISPR 22 Class B, EN55022 Class B, FCC CFR47 Part 15, EN 62311, IEC 61000-3-3:2008, EN 61000-3-3:2008, ICES-003 issue 4 Class B, EN 61000-3-2:2006+A1:2009+A2:2009, IEC 62479, EN 62479:2010, IEC 62311, IEC60950-1:2005+A1:2009, VCCI V-3/2011.04, EN 55024:2010, EN 301 489-1, EN 301 489-17, EN 60950-1:2006+A11:2009+A1:2010+A12:2011
