Thin is in, and this HP ENVY laptop delivers. This superbly sleek, elegantly designed body packs the power of a high-performance PC. It's portable. It's beautiful. It's going to be your new infatuation.
Thin just got thinner
At just 12.9 mm, the thinnest notebook we’ve ever made is guaranteed to intrigue, with an artfully-crafted all-metal body and stunningl Quad HD+ display.
Engineered for excellence
With 6th generation Intel® Core™ i5 processors2, up to 128 GB SSD, and a full range of ports, performance and supreme thinness go hand in hand.
Impressive endurance
Don’t let the size fool you. This lightweight beauty packs a heavy-hitting battery.
High performance
- Intel® Core™ processors deliver cutting-edge performance. With dual-core processors you’ll enjoy stunning visuals, effortless multitasking, increased speed and enhanced security to help you create, play, entertain and achieve.
6th generation Intel processors
- Enhance your computing experience with the latest processors from Intel.
Windows 10 Home
- Windows 10 Home is here. Do great things.
Sleek design
- Easily take this thin and light PC from room to room or on the road.
QHD+ display
- Spectacular entertainment from ultra-wide viewing angles with the incredible image quality of QHD+.
Bang & Olufsen with dual speakers
- Dual speaker sound, designed for true audio perfection on a PC.
HP Solid-State Drive
- Load your apps fast with quick and efficient HP Solid-State Drives.
Backlit keyboard
- Keep going comfortably even in darker environments.
HP SimplePass security
- Access online accounts5 with the swipe of a finger.
Power on.
- Charge devices even in sleep mode with HP USB Sleep and Charge.
Packed with ports
- Connect easily.
- Windows 10 Home or other operating systems available
