Keep the pace in and out of the office with the HP ElitePad 1000 Rugged Tablet, a Windows tablet solution designed to go wherever you go and do whatever you do-throughout the day.
Use the durable solution wherever you need it. It's designed to be cleaned and pass IP 65 for water and dust and MIL-STD 810G testing.
Mobile productivity that works as hard as you do
Power through your shift with up to 20 hours battery life and use the 2D barcode reader (select configurations) to quickly access information such as inventory data.
Security from the start
Make the solution part of your secure IT environment with an integrated smart card reader with FIPS-140-2 encryption and IPS-201 certification, HP Client Security and HP BIOS Protection solutions, and full disk encryption.
Expand what you can do
Create the best solution for your environment with a suite of optional accessories. Use the tablet pen to enable data input when you're out in the field or a docking station to create a desktop-like environment when you're back in the office.
Intel Atom Z3795 / 1.59 GHz, up to 2.39 GHz / 2 MB Cache
4 GB LPDDR3
Storage
128 GB eMMC
Display
10.1" LED backlight touchscreen 1920 x 1200 / WUXGA
Graphics
Intel HD Graphics
Input Device
Digitizer
Integrated Webcam
802.11a/b/g/n, Bluetooth 4.0, NFC
2-cell - up to 13 hours
Ambient light sensor
Dockable
Security
Trusted Platform Module (TPM 1.2) Security Chip
26.1 cm x 17.8 cm x 0.92 cm
680 g
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 1 year , Limited warranty - battery - 1 year
Tablet - no keyboard - rugged
Operating System
Windows 8.1 Pro 64-bit Edition - English
Processor / Chipset
CPU
Max Turbo Speed
2.39 GHz
Number of Cores
Quad-Core
Cache
L2 - 2 MB
64-bit Computing
Intel Burst Technology
RAM
4 GB
LPDDR3 SDRAM
Speed
1067 MHz
Storage
Main Storage
128 GB eMMC
Display
10.1"
LCD Backlight Technology
LED backlight
Touchscreen
Yes (multi-touch)
Resolution
1920 x 1200 (WUXGA)
Widescreen
Image Aspect Ratio
16:10
Anti-smudge, Corning Gorilla glass 3
Audio & Video
Graphics Processor
Intel HD Graphics
Camera
Resolution
8 Megapixel (rear), 2.1 Megapixel (front)
Camera Features
LED flash
Sound
Stereo speakers, two microphones
High Definition Audio, DTS SOUND+
Input
Digitizer
Communications
Wireless
Bluetooth Class
Class 2
Wireless Controller
Broadcom BCM43241
IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED
2-cell lithium polymer
30 Wh
Run Time
Up to 13 hours
AC Adapter
Input
Output
10 Watt, 9 V, 1.1 A
Connections & Expansion
Headphone/microphone combo jack , Dock
Memory Card Reader
Yes (microSDXC)
Software
Software Included
HP SoftPaq Download Manager, HP Support Assistant, HP ePrint, HP Setup, PDF Complete Corporate Edition, Netflix, HP Wallpaper, Password Manager, Amazon Kindle, Windows Defender, HP Registration, HP Client Security, HP Mobile Connect, Device Access Manager with Just In Time Authentication, HP PageLift, Absolute Data Protection (4 years subscription), Box.net 50GB storage, HP Trust Circles Standard, HP Manageability, HP UEFI System Diagnostics, HP Wireless Hotspot, HP Software Setup, T-Mobile Malwarebytes Anti-Exploit (MBAE)
Case Material
Aluminum
Integrated Options
Dockable
Security
Digital compass, Accelerometer, gyroscope, Haptics
