Elegant, sleek, user-friendly, and designed to perform, the HP EliteOne 800 is ready to deploy in demanding environments, with manageability and security, enterprise-class collaboration technologies, and touchscreen configurations.
Place it here, there, and everywhere
Deploy this redesigned, stylish All-in-One with a 58.4 cm (23") diagonal FHD display anywhere you need a powerhouse PC. Its slim design and integrated cable management make an impression at reception, on an executive’s desk or mounted on a wall.
Deeply secure
Help secure your PC with comprehensive hardware and software tools like an optional fingerprint reader and HP BIOSphere with Sure Start’s customizable BIOS-level passwords.
Power-packed performance
Drive your most demanding workloads with an All-in-One powered by fast 6th Gen Intel® Core™ processors, plus AMD Radeon™ R9 360 discrete graphics with 2 GB GDDR5 for your most challenging use cases.
Count on premier audiovisual clarity
Collaborate naturally with Cortana on Windows 10 Pro, optional 10-point capacitive touch, Audio by Bang & Olufsen, HP Clear Sound Amp, HP Noise Reduction Software, and a 2MP HD webcam.
Featuring
Let nothing stand in your way
Help protect from today’s security threats and maximize management and productivity features for business with Window 10 Pro.
Ready to run, and upgrade
Make expansion and upgrades a snap with a tool-less rear access panel.
World-class management
Simplify IT manageability with Intel® vPro™8 and Windows 101 plus HP Common Core BIOS, which enables easy management of your entire fleet of HP devices.
Tested to go the distance
Rest easy with a PC that passed 120,000 hours of testing and is designed to undergo MIL-STD 810G9 testing.
Consistently stagger deployments
Get the same HP configuration across the globe, available in more than 180 countries where HP conducts business.
Make your workspace more workable
Make more room with optional, versatile stands or a space-saving VESA wall mount10 for a range of use cases.
Fast easy login
Save time and help eliminate the need for cumbersome complicated passwords by using the integrated fingerprint reader.
Windows 10 Pro 64
