Strike envy across the office with the elegance of the UHD HP EliteDisplay S270n 4K Micro Edge Monitor. It delivers style and simplicity with a modern 3-sided micro-edge bezel and easy single-cable USB-C connectivity to your device.
Speed deployments with out-of-the-box readiness and quickly connect your video sources to the display with one DisplayPort 1.2 and two HDMI, in addition to the USB-C port.
Conserve power and costs
Be energy-smart when you deploy a design that is ENERGY STAR certified and EPEAT 2019 registered.
Divide and conquer
Design the screen for how you work with HP Display Assistant software, which enables screen partitioning and helps deter theft by dimming a display that's disconnected without approval.
HP EliteDisplay S270n - LED monitor - 4K - 27" - Smart Buy
LED-backlit LCD monitor - 27"
Energy Class
Class C
Energy Consumption per Year
64 kWh
Power Consumption (On mode)
44 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
4K 3840 x 2160 at 60 Hz
Pixel Pitch
0.1554 mm
Brightness
350 cd/m²
Contrast Ratio
1300:1 / 10000000:1 (dynamic)
Response Time
5.4 ms (grey-to-grey with overdrive)
Colour Support
1.074 billion colours (10-bit)
Colour Gamut
99% sRGB
Input Connectors
2xHDMI, DisplayPort, USB-C
Display Position Adjustments
Height, tilt
Screen Coating
Anti-glare
Voltage
Black, chrome plated, black onyx (base)
61.35 cm x 18.99 cm x 49.85 cm
English / United Kingdom
Manufacturer Selling Program
HP Smart Buy
Environmental Standards
ENERGY STAR Qualified
Plug and Play, VCCI, BSMI, WHQL, CB, CCC, FCC, RoHS, ISO 9241-307, WEEE, ICES, cTUVus, ERP, CEL Grade 1, RCM, MSIP, CoC, low halogen, CU
Display Type
Energy Class
Class C
64 kWh
Diagonal Size
27"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.1554 mm
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
99% sRGB
Response Time
Vertical Refresh Rate
24 - 60 Hz
Horizontal Refresh Rate
27 - 135 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
USB-C power delivery up to 60 W, 3-sided micro-edge, 99% sRGB colour gamut
61.35 cm x 18.99 cm x 49.85 cm - with stand
USB-C/DisplayPort 1.2 Alt Mode , 2 x HDMI (HDCP) , DisplayPort (HDCP)
Mechanical
Height, tilt
Tilt Angle
-5/+23
Height Adjustment
100 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), arsenic free
VESA bracket
1 x HDMI cable - 1.8 m , 1 x DisplayPort cable - 1.8 m , 1 x USB-C cable - 1.8 m
Backlight Life
30,000 hours
HP Smart Buy
Security Slot Type
Kensington security slot
Input Voltage
44 W
Power Consumption (Typical)
55 Watt
Power Consumption Stand by
0.5 Watt
Included Software
Microsoft Windows 7 / 8 / 10
Dimensions & Weight Details
Without stand - width: 61.35 cm - depth: 4 cm - height: 36.25 cm - weight: 4.85 kg , With stand - width: 61.35 cm - depth: 18.99 cm - height: 49.85 cm
