Create a dual-display mobile workspace almost anywhere with the HP EliteDisplay S140u 35.56 cm (14") USB Portable Monitor, an ultra-compact, strikingly thin, high-resolution display in a wraparound cover. Fold it back to add a second screen for your Windows tablet or notebook and connect with one USB cable.
Sleek, stylish, and ultra-portable.
The super-compact, ultra-thin design weighs 1.44 Kilograms, and is just 1.27 centimeters thick. The cover doubles as an adjustable stand and helps protect the display so you can slide it into your carrying case with your tablet or notebook.
Double your visual workspace.
Pair the 1600 x 900 high-resolution display with a notebook or tablet to extend to a dual-display setup wherever you work, or make a big impression with mirror mode.
Super simple set-up.
Get ready in a snap with the single USB cable that also acts as a power source. Fold back the cover and connect to any USB port on your notebook or tablet and you’re ready to work.
