Multi-task to your heart's desire in Quad HD on the HP E272q 68,6 cm (27") QHD Monitor, which also has adjustable comfort features to help you power through your day.
Attach your HP Desktop Mini, HP Chromebox, or select HP Thin Client directly behind the display. Keep things tidy with an integrated power supply and cable management features.
Reduce power consumption and help lower costs
Get an intelligent, energy-efficient design that is ENERGY STAR certified, EPEAT Gold registered, and meets TCO Certified Edge requirements with 85% Post-Consumer Recycled plastics.
Your monitor's new best friend
Design the screen for how you work with HP Display Assistant software, which enables screen partitioning and helps deter theft by deactivating a monitor that's disconnected without approval.
Make it yours
Customize a complete solution with HP accessories designed and tested to work with your display.
Backed by world-class support specialists
Get three years of service and support, and extend your protection with optional HP Care Packs.
HP EliteDisplay E272q - LED monitor - 27" - Smart Buy
Brightness, contrast, input select, colour temperature
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
Mercury free, arsenic-free glass
Black, silver
64.32 cm x 19.7 cm x 40.94 cm - with stand
6 kg
DisplayPort , VGA , HDMI , USB 2.0 upstream , 2 x USB 2.0 downstream
Mechanical
Display Position Adjustments
Tilt Angle
-5/+25
Swivel Angle
90
Rotation Angle
90
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
1 x DisplayPort cable - 1.8 m , 1 x VGA cable - 1.8 m , 1 x USB cable - 1.8 m
Backlight Life
30,000 hours
Compatible with Windows 7
With stand - width: 64.32 cm - depth: 19.7 cm - height: 40.94 cm - weight: 6 kg , Without stand - width: 64.32 cm - depth: 4.8 cm - height: 39.25 cm - weight: 3.8 kg
