IPS goes mainstream with the HP EliteDisplay E241i 61 cm (24') IPS LED Backlit Monitor, a business-class combination of a large screen, extra-wide viewing angles, and extraordinary comfort.
Crisp, clear content on this 24-inch diagonal, 16:10 aspect ratio screen from the high 5M: 1 dynamic contrast ratio. Connect with VGA, DVI, and DisplayPort inputs and integrated two-port USB hub.
See more, do more, and be more comfortable
Create a whole world view with a monitor for every task. With multiple monitors, you can design a workspace that puts everything you need front and center on the desk.
Your monitor's new best friend
Personalize your screen with HP Display Assistant software and view open applications on your connected displays. Deter theft with a user-designated PIN that deactivates the monitor if disconnected.
Global reassurance
Rest assured your IT investment is supported by a three-year standard limited warranty. To extend your protection beyond the standard warranties, select optional HP Care Pack Services.
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
HDCP
Meteorite
55.6 cm x 5.5 cm x 36.26 cm - without stand
4.11 kg
USB 2.0 upstream , 2 x USB 2.0 downstream , DVI-D (HDCP) , DisplayPort (HDCP) , VGA
Mechanical
Display Position Adjustments
Tilt Angle
-5/+30
Swivel Angle
360
Rotation Angle
90
Height Adjustment
150 mm
Security lock slot (cable lock sold separately), Low-Smoke Zero Halogen (LSZH)
1 x VGA cable - 1.8 m , 1 x DisplayPort cable , 1 x USB cable
Backlight Life
30,000 hours
Compatible with Windows 7
Without stand - width: 55.6 cm - depth: 5.5 cm - height: 36.26 cm - weight: 4.11 kg , With stand - width: 55.6 cm - depth: 27.62 cm - height: 51.65 cm - weight: 6.58 kg
