Work smart and comfortably with the HP EliteDisplay E232 58,4 cm (23") Monitor, a large-screen Full HD IPS display with Elite-class presentation features and ergonomic adjustability for everything you do every day.
Attach your HP Desktop Mini, HP Chromebox, or select HP Thin Client directly behind the display. Keep things tidy with an integrated power supply and cable management features.
Reduce power consumption and help lower costs
Get an intelligent, energy-efficient design that is ENERGY STAR certified, EPEAT Gold registered, and meets TCO Certified Edge requirements with 85% Post-Consumer Recycled plastics.
Your monitor's new best friend
Design the screen for how you work with HP Display Assistant software.
Make it yours
Customize a complete solution with HP accessories. Use the HP Speaker Bar for audio, an HP Single Arm to take the display off the desk, or an HP USB Graphics Adapter for multi-monitor setups. Go stand-less with the head-only model.
Backed by world-class support specialists
Get three years of service and support, and extend your protection with optional HP Care Packs.
HP EliteDisplay E232 - LED monitor - Full HD (1080p) - 23"
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
HDCP, On-screen Digital Controls
54.93 cm x 18.9 cm x 54.99 cm - with stand
5.7 kg
USB 2.0 upstream , 2 x USB 2.0 downstream , VGA , DisplayPort (HDCP) , HDMI (HDCP)
Mechanical
Display Position Adjustments
Tilt Angle
-5/+30
Swivel Angle
45
Rotation Angle
90
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), detachable stand
1 x VGA cable - 1.8 m , 1 x DisplayPort cable - 1.8 m , 1 x USB cable - 1.8 m
Backlight Life
30,000 hours
Compatible with Windows 7
Without stand - width: 54.93 cm - depth: 4.96 cm - height: 33.69 cm - weight: 3.63 kg , With stand - width: 54.93 cm - depth: 18.9 cm - height: 54.99 cm - weight: 5.7 kg
