Be productive and comfortable with the HP EliteDisplay E222 54,6 cm (21.5") Monitor, a Full HD IPS display that delivers crisp, clear color for all of your projects and excellent ergonomic adjustability at an attractive price point.
Attach your HP Desktop Mini, HP Chromebox, or select HP Thin Client directly behind the display. Keep things tidy with an integrated power supply and cable management features.
Reduce power consumption and help lower costs
Get an intelligent, energy-efficient design that is ENERGY STAR certified, EPEAT Gold registered, and meets TCO Certified Edge requirements requirements with 85% Post-Consumer Recycled plastics.
Your monitor's new best friend
Design the screen for how you work with HP Display Assistant software.
Make it yours
Customize a complete solution with HP accessories designed and tested to work with your display.
Backed by world-class support specialists
Get three years of service and support, and extend your protection with optional HP Care Packs.
HP EliteDisplay E222 - LED monitor - Full HD (1080p) - 21.5" - Smart Buy
LED-backlit LCD monitor - 21.5"
Energy Class
Class A
Energy Consumption per Year
29 kWh
Power Consumption (On mode)
20 W
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.24795 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
7 ms (grey-to-grey)
Colour Support
16.7 million colours
Colour Gamut
72%
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare
Voltage
AC 120/230 V
Black, silver
51.37 cm x 18.9 cm x 33.35 cm
5.27 kg
English / United Kingdom
Manufacturer Selling Program
HP Smart Buy
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
Plug and Play, CSA, UL, VCCI, BSMI, NOM, TUV S, WHQL, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, MEPS, KC, CECP, EAC, CEL Grade 1, ISC, SEPA
Display Type
Energy Class
Class A
29 kWh
Diagonal Size
21.5"
Built-in Devices
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.24795 mm
Pixel Per Inch
102
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
72%
Response Time
7 ms (grey-to-grey)
Vertical Refresh Rate
50 - 75 Hz
Horizontal Refresh Rate
30 - 80 kHz
Video Bandwidth
170 MHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
WLED
Controls & Adjustments
Brightness, contrast, input select, colour temperature
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
HDCP, Mercury free, arsenic-free glass
Black, silver
51.37 cm x 18.9 cm x 33.35 cm - with stand
5.27 kg
USB 2.0 upstream , 2 x USB 2.0 downstream , HDMI (HDCP) , DisplayPort (HDCP) , VGA
Mechanical
Tilt Angle
-5/+25
Swivel Angle
90
Rotation Angle
90
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), detachable stand
1 x VGA cable - 1.8 m , 1 x DisplayPort cable - 1.8 m , 1 x USB cable - 1.8 m
Backlight Life
30,000 hours
HP Smart Buy
Input Voltage
AC 120/230 V
20 W
Power Consumption (Typical)
23 Watt
Power Consumption Stand by
0.5 Watt
Included Software
Microsoft Windows 7, Windows 8.1, Windows 10
Dimensions & Weight Details
Without stand - width: 51.37 cm - depth: 4.98 cm - height: 31.69 cm - weight: 3.26 kg , With stand - width: 51.37 cm - depth: 18.9 cm - height: 33.35 cm - weight: 5.27 kg
